Curved wand for pressure washer
Bob_Vaughn
I have been looking for a curved pressure washer wand for reaching underneath my rv and truck. I picked up a lot of dirt on our trip to Alaska last summer. So far I have not been able to locate such a critter so maybe they do not exist.....
11 REPLIES 11
Veebyes
Have one, though did not get it for vehicle cleaning. The thrust of using it takes some getting used to.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
holstein13
I'd go with This.
These guys are experts in all things related to pressure washers.
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
F1bNorm
Our regular boondock spot turns to sticky mud if we get caught in the rain. This water Wand works great getting the mud out of the wheel wells. They're well made, look for one with a curved shaft.
Norm
F1BNorm
rockhillmanor
They are called gutter cleaner wands. Do a search for residential gutter cleaner hoses and wands.
the cheaper route is just go into the garden center at walmart. You'll find a plethora of curved watering wands some with variable heads for higher pressure.
Old-Biscuit
RoyB wrote:
I was always afraid to use a pressure washer around the RV's. I suspect the outside walls are just as thin as the inside walls are...
That and the graphics.....then the underside. Who knows where water would be blown into using pressure washer.
RoyB
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Kit_Carson
I saw an attachment for a power washer at Home Depot the other day that was curved as you describe. It is intended to clean the gutters around your home. Check it out....it might be just what you are looking for.
KIT CARSON
GOOD SAM LIFE MEMBER
USAF VETERAN
ARS: KE5VLE
NORTHWEST LOUISIANA
wa8yxm
Curved pressure wands are hard to find because the side pressure with a good pump will pull (or rather push) it right out of your hands.
Use a low pressure wand if you want curved. (City water pressure)
onemilmhz
I bought an extension like this and attached it to my existing wand. They also make a telescoping version but it's significantly more expensive. I've seen similar extensions for the plastic electric type wands if that's what you have.
TV - 2003 Ford F150 SuperCrew FX4
TT - 1979 Holiday Vacationer (Hunting Lodge!)
Tent - Coleman Adler Creek
newman_fulltime
If your wand has quick connects you can get some compression hydrolic fittings and make your own
