Dewinterizing
NY_RVer
Has anyone in the northeast dewinterized yet who hasn't headed south? Possibly taking a trip in the next week or two and wanted to clear out the antifreeze and fill the fresh water tank, but am concerned about temps still falling into the 30's at night. Just curious what others have been doing.
2016 Ram 3500 Laramie Crew Cab 4x4 SRW 6.7 Cummins
2014 Jayco Jay Flight 28BHBE
Reese Dual Cam
12 REPLIES 12
mowin
rhagfo wrote:
mowin wrote:
Doing mine tomorrow. Neighbor did his today. Would have to be 32 for a while to freeze the lines up. If I feel theres a risk, I'll leave the furnace on till morning.
Stop and think how long it takes for even small ice cubes to freeze in your freezer!!!
If the midday temps get close to 50 degrees, you will likely be good down to 28 overnight. Water tank would take over a day to freeze even at 28 or so.
I will add that I don't use antifreeze in the water lines, traps only. I blow my lines, no flushing required.
Like I said, it would have to be 32 for a while to freeze things up. Not just a hr or two over night. Had one night hit 28*, but the day before was almost 70. No issues at all.
GaryWT
What a difference a week makes, temps are nice now. I will do mine today or next week as we head out May 1 for our first trip. Started doing things yesterday.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR 2014 F350 Crew Cab 6.2L 3.73
NY_RVer
Finally got around to it yesterday. Flushed antifreeze, fillled fresh water tank, ran water heater, checked tire preaaure, and finished changing all bulbs to LED. Now I just have to take a trip somewhere! Thanks for all the suggestions, next year I may just blow out the lines.
Reese Dual Cam
TurnThePage
For future reference, you may want to consider draining the antifreeze right after you use it. It's purpose is to displace any water left in the lines. Once it's done that, it no longer needs to be there.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
nettech207
Did mine the other day temp have been reaching 50 in MA
rhagfo
PCronin68
Did mine last week. Heading to Ft Myers Beach this week for family vacation
2014 Fleetwood Bounder 34b
mowin
Goostoff
I'm not in the north east but I did mine today. We have reservation in 2 weeks so I am trying to get everything done while I have good weather.Its supposed to rain tomorrow and who knows what next weekend will bring in Wisconsin spring
1993 Chevy C3500
2005 Cedar Creek 34RLTS
JaxDad
I use air not pink stuff so 'dewinterizing' for me involves adding water and flipping on the pump.
I do it numerous times per winter so if the temps it means nothing to me.
I'm quite a ways north of you too.
Redterpos3
our temps finally look like they will hold for some time. But it's always a risk before Mother's Day around Central PA. Still I dewinterized today. I will keep an eye on weather lows, and turn on furnace if there is danger. It certainly won't be for long, so with a little precaution should be ok, I'm figuring!
The Travelin' Terrapins!
2016 Ford F-350 SRW;CC;4x4;172WB;6.7PSD;34,000m
2011 Nash 27T 12,995m
2013 Yr1 30nts 3150m
2014 Yr2 52nts 3365m
2015 yr3 25nts 2260m
2016 yr4 46nts 2500m
2017 yr5 24nts 1720m
2018 yr6 4nts 30m
brirene
Temps falling into the 30's won't do any harm unless they fall to 32 or less. Even then, if daytime temps rise into the 40's+, you should be fine. What I do in iffy situations is set the furnace to lowest setting overnight If it's getting below 32.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
