โOct-10-2013 08:46 AM
โOct-10-2013 01:15 PM
โOct-10-2013 11:30 AM
โOct-10-2013 09:46 AM
โOct-10-2013 09:22 AM
โOct-10-2013 09:18 AM
โOct-10-2013 08:59 AM
โOct-10-2013 08:54 AM
TucsonJim wrote:
Check the handle. Open the door and watch the latch while you slowly pull the handle. If there is too much play, the linkage in the handle may be getting worn out and the mechanism needs replacing.
โOct-10-2013 08:53 AM
Terryallan wrote:
Is it setup? And if so, Do you have it sitting on the stabilizers instead of the wheels? In other words. Did you use the jacks to lift one side to make it level. Instead of raising it with blocks under the wheels? If that is the case. You could have put the frame in a bind, which put the door in a bind, and would make it hard to open.
Don't know if you did. But the stabilizers are not for leveling.
โOct-10-2013 08:52 AM
โOct-10-2013 08:51 AM
