โOct-08-2014 07:21 AM
โOct-05-2015 09:25 AM
โOct-05-2015 08:51 AM
โOct-04-2015 02:04 PM
โOct-09-2014 05:29 AM
โOct-08-2014 03:26 PM
jmtandem wrote:
If you want to upgrade to a hitch that eliminates sway, not just mitigates it, get the ProPride or Hensley. They are in a completely different hemisphere concerning sway elimination from the Equalizer or other friction based hitches.
โOct-08-2014 03:07 PM
โOct-08-2014 01:45 PM
Cooter_76 wrote:
Tires were set at the 35 PSI per the sticker on my door. Max PSI on the tire is listed at 44. I'll add some air the next time I tow.
Will stick with this hitch setup for now. If I wind up towing more often than I anticipate (twice/year) I might invest in a better WD setup.
โOct-08-2014 01:02 PM
โOct-08-2014 12:21 PM
APT wrote:
Start with those free changes, lower ball height, restore all weight (or estimated by body height) front axle weight, increase tire air pressure when towing. I suspect you'll see improvements.
โOct-08-2014 11:34 AM
โOct-08-2014 10:32 AM
jerem0621 wrote:
OP...I also suggest to add a second sway bar. You can find the sway control for around $30.00 online at Harbor freight and then use the 20% off coupon.
Thanks!
Jeremiah
โOct-08-2014 10:09 AM
cbwallace wrote:tonymull wrote:
If you think getting sucked in by big rigs is normal you really need to try an Equal-I-Zer or Reese...you won't feel them any more'
I absolutely agree! I have towed several thousand miles on busy Interstates with an Equalizer hitch and not sure I can recall a single time I was sucked in by a passing vehicle.
โOct-08-2014 09:53 AM
