Grease for WDH
Massey16
Any grease work for the ball and where the trunnions meet the hitch head? Oil instead on the trunnions (if so, which kind)?
Thanks!
24 REPLIES 24
bfourman
Spray can of white lithium grease lives in my storage compartment. I spray the ball and bars each time I hitch up.
'00 GMC Yukon XL K2500 - 6.0L, 4L80e, 3.73s, P3, AirLift, BlackBear tuned.
'14 Aerolite 282DBHS - Andersen No-Sway
Lynnmor
Crabbypatty wrote:
The creek of the hitch on turns is the wd bars doing what they are supposed to do. The only grease is on the hitch ball. If Ihave to make a super sharp turn like pulling into a site. I will remove the bars, but thats only happened once in 11 years.
Wrong. You are to oil the trunnions, read the instructions.
Crabbypatty
John, Lisa & Tara:B:C:)
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
Lynnmor
e.menoche wrote:
I've had basically the same question. My hitch creaks on sharp, slow turns, but my dealer said that is normal, so I haven't worried about that. However, the latching mechanism on my trailer frame has gotten rusty and very balky to move so that it clamps down against the hitch ball. And at times, I've had a hard time getting the hitch ball to release. Bought a sledge hammer to persuade it, just in case. I've thought about spraying some dry lube graphite on the latching mechanism, but was wondering (1) is that OK to do and (2) would it work. Or what else might work.
OIL
wannabervin
Racerchaser27
Ron3rd wrote:
Just pick the color you want on your pants. I have some Mobil 1 Red Synthetic I use for wheel bearings, so that's what I use on the WD hitch.
LOL....been there. One trick I use is after I unhook, I tie a WalMart or any other shopping bag over the ball either in a knot or with an elastic. Works like a charm and have been told at many a race track by others that they wish they thought of that before they ruined their pants. A little while later, I see those people tying bags on there hitches. Cheap...and easy!
And yes, I grease both the ball and cams with whatever grease I have lying around the garage or in the grease gun. I also always use gloves while handling the bars and wipe them down with brake cleaner when I get home.
mkirsch
Nomad II
Nomad II
To get the grease off your pants, get some Goo Gone and some Simple Green. Spray the Goo Gone on the grease first, and let it soak in for a few minutes, then hit it with the Simple Green. Toss it in the wash with your regular clothes, or do a separate load if it bothers you. Grease comes right out.
mosseater
I've heard the horror stories about grease, and pants, and wiping (Oooooo, the wiping!!!) I'm not gonna lie (this time), I have gotten a little grease on my pants once or so, and I do carry a roll of paper shop rags at the ready. If I'm travelling any decent distance, I grease it up pretty well. A dollop on the ball and spread it around, a dab on each of the four contact points on my trunnion head, and a dab of Vasoline on the two bar/cam interfaces. When I get to my destination, the first thing I do after the dust has settled, is wipe down the grease and road dirt off the parts, cover the ball with my custom plastic cover and place all the components in the bed of the truck for the duration of the stay. Takes all of 5 minutes and I'm done and ready for clean hitch up on the way home. Just a hiddeous usage of time and materials, I know.
The bright side is, my parts are beautifully seated, make little or no noise, and will last a looooong time. Ohhh, the horror!
"It`s not important that you know all the answers, it`s only important to know where to get all the answers" Arone Kleamyck
"...An unarmed man can only flee from evil, and evil is not overcome by fleeing from it." Col. Jeff Cooper
Sunset Creek 298 BH
pitch
Sounds like everyone is over greasing. I just thoroughly coat the ball with a finger tip of grease and the wipe it with a rag,same with the bars. You do not need to even see the grease, all you are doing is reducing the friction,and it does not take much. I use maybe a ยผ to ยฝ teaspoon, and have a quiet hitch.
Ron3rd
Another tip is to put a latex rubber glove over the ball when unhitched. I carry a cheap box of these and they work great for that purpose.
Equilizer Hitch
Honda EU2000
Dave_H_M
gcloss wrote:
Ruined many pants and shorts this way.
You sure those stains were on the outside of your shorts? :E
That white grease comes in a spray bomb which to me would make application easier.
ken56
Better buy a box of shop rags while your at it 'cause it does get all over the place if your not careful. Then you have the problem of how to store those greasy WDH bars and hitch when at the campground, all while not contaminating them with dirt. I lay my bars across the battery box and put the hitch on the ground with a zip lock baggie on the ball. I have a bike lock cable that I put thru the chains and hole in the hitch and then around the A frame to secure them. works great for me.
FrankShore
Hahaha
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
DRKMinWA
I was gifted some Reese's trailer ball lube and it works fine on my E2. Prior to the Reese's i used marine bearing grease.
They both have the same attractiveness to denim or shins.
Rick & Kathy
2014 Econ 16RB
2013 Nissan Titan Crew Cab
