grease on TT brakes. what will happen?
TNRIVERSIDE
I pulled my TT brake durms to inspect and repack the bearings. I was surprised to find a small amount of grease on the outside of the seal. Fortutaly there was no grease on the drum or business side of the shoes. With only 5,000 miles I did not expect to see a seal failure. I did NOT add grease using the grease fitting on the axle. So hear the question.
If I had added grease to the bearings using the fitting on the axle with the failed seal what would be the outcome other than grease on the shoes and an expensive repair bill?
Would there be only brake failure?
Possible fire?
2014 Coleman CTS192RD. 2009 F150 4X4, 5.4, 3.31
Jeff
13 REPLIES 13
TNRIVERSIDE
Yes I did replace the seal on the one inbord bearing that showed sings or leakage. I removed the bearing. Inspected and repacked it. I also removed inspected and repacked all 4 outboard bearings. All bearings were repacked by hand. That's the last time I'll do that. I'll use the cone and a grease gun from now on.
My shoes did not have grease on the business side. But a very small amount had slung out onto the inside of the shoes. But my question was what would happen if I had pumped grease into the fitting with a bad seal.
Thanks for all the help.
Jeff
Dave_H_M
When I read the OP, I thought I noticed that the brake shoe did not have any grease on it.
That small amount on the seal could have been there when the original installer got a little dab on the wrong side of the seal.
BenK
First fix what caused this
Second...I'd replace the shoe with new
Ask how much are you saving by trying to salvage that shoe? How much would you
spend using up the cleaner and other stuff?
Friction material does absorb, but not a whole lot. When it absorbs brake
fluid, the friction material becomes 'grabby' and is ruined
Also agree with changing out the seals every time I take this kind of thing
apart.
Again, how much is the trailer, TV and those aboard worth to you vs the savings
in salvaging the shoe (questionable if you can salvage it)
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
deltabravo
In this case (my trailer) it was a far more efficient use of my time to repalce the entire brake assembly (on all 4 wheels) rather than spend a small fortune on brake cleaner and the time and effort, and subsequent mess I'd creat if i cleaned them.
The below is an example of what can eventually happen when someone continually pumps grease in using the zerk on the end of the axle - eventually the excess grease blows out the seal and contaminates the brakes. The previous owner os my race trailer thought all he needed to do was pump grease in every year. He was treating it like a boat trailer with Bearing Buddies.
The other 3 wheel positions were far worse than this one:
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
deltabravo
Did you replace the seals?
I always replace the seals when I service bearings.
azrving
Ivylog wrote:
I use a torch to burn the grease out of the linings and then wire brush them. Have only been doing this for 50 years.
50 years? Good thing that the asbestos hasn't messed you up. I remember when they used to arc the shoes to fit the drum. Cough hack hack hack
TNRIVERSIDE
Thanks for all the replies. As always there is a wealth of knowlage here.
Jeff
mbopp
In my younger days I would boil contaminated brake shoes in a water / detergent solution to save them. Mom wasn't too thrilled.....
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
TucsonJim
Campfire Time wrote:
No, you don't need new brakes. Clean them good with Brakcleen then lightly sand the shoes with 120 grit sand paper. They will be fine.
X2 - They CAN be cleaned properly. Don't forget to thoroughly clean the drums too. Brakleen (proper spelling) and sand paper will get you down to clean shoe material. It's a falsehood that grease will penetrate deeply into brake linings and can't be removed. In my years as a mechanic, I've cleaned many sets of contaminated brakes and never had a problem after. In my experience, when a mechanic tells you otherwise, he's trying to sell you a complete brake job for hundreds of $$ instead of cleaning the mess for $50.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
Ivylog
Upgraded with a 08 HR Navigator 45’...
Campfire_Time
Chuck D.
“Adventure is just bad planning.” - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
Ductape
Just loss of braking efficiency. I've had it happen. You'll need new brake shoes if they get lubed.
49 States, 6 Provinces, 2 Territories...
donn0128
Loss of braking action. Brake shoes once contaminated can never be cleaned. They just become garbage.
