โSep-11-2013 07:40 PM
โSep-20-2013 07:44 AM
pianotuna wrote:X2 What an overpriced piece of junk! Do the same thing with an electric box heater or two for about 1% of the cost and you don't wear out or have to listen to your furnace fan either..
Hi,
If you think a heat strip is expensive, be prepared for "sticker shock" when you look at the so called "cheap heat" system.
I've "rolled my own" for about $250.00 total cost.
โSep-19-2013 02:39 PM
โSep-19-2013 12:37 PM
โSep-19-2013 08:37 AM
โSep-19-2013 08:27 AM
โSep-19-2013 08:15 AM
โSep-19-2013 08:05 AM
camperforlife wrote:
I had one, used it frequently and it does exactly what you want it to do,take the chill off. If you turn it on and expect instant heat, yo will be disappointed.
โSep-19-2013 07:23 AM
โSep-19-2013 06:56 AM
โSep-19-2013 02:51 AM
B.O. Plenty wrote:
1500 watts is about 5200 BTUs. It won't matter if it's a heat strip, electric fireplace, "Amish" heater or milkhouse type heater. They all put out the same amount of heat for the same amount of power. Why waste more energy to run your A/C fan or other just to try and blow that little amount of heat around?
โSep-18-2013 09:03 PM
โSep-18-2013 07:53 PM
โSep-12-2013 12:04 PM
โSep-12-2013 06:00 AM
rvten wrote:
A heat pump unit and a heat strip add on are 2 different things.
Other than being a little noisy. They are great to about 40 deg.
They make no more noise than your A/C.
