Helpful hint when putting down a bead of caulk
mdcamping
Just learned this trick the other month, after putting down a bead of caulk, spray windex on it and then do the finish spread. (The windex is very slippery where the caulk will not stick to your finger)learned this from our local rv service dealership... makes the job so much easier and makes a real nice finish.
Mike
2022 F-150 3.5 EcoBoost 4X4 Supercrew GCWR 19,500 157WB
Payload 2476 Maxtow 13,800 3.73 Equalizer 4 Pt Sway Hitch
2017 Jayco Jay Flight 24RBS
Old TV, 07 Toyota Tacoma, Double Cab, Factory Tow Pkg, retired towing at 229K. (Son now owns truck)
20 REPLIES 20
RAS43
I knew that and cleaned the caulk line first. But the Windex sprays a larger area and ran down the side.
jsr21
You shouldn't have any wax residual where you want to put caulk..won't stick
RAS43
Well, I tried this tip out this week since I am one of those "spit guys". Not dead yet after all these years! Anyway, the Windex did work well with just my finger and beads looked good. However, I did notice streaks in the surface and found that the Windex took off the wax. I had to rewax those areas around where I had worked. Besides ammonia Windex has 2 different alcohols in it. Since I like the shine my waxing leaves on my 5'er I think I'll try just water next time.
Carb_Cleaner
As I understand it, mineral spirits attacks the nervous system and its production process is horrible for the environment. I used it years ago, painting my way through school, but soon switched to spit or water. A product called "Goof Off" (a glue and latex paint remover) works well, too.
"If you can step across it, you can caulk it."
"Caulk and paint,
make a Carpenter what he ain't"
'13 F250XL SC gas 4x4 8', Camper & Plow packages, StableLoads, LT285/65R-18 Goodyear Wrangler A/T Adventure, 18x9 Ultra Motorsports "Phantom" wheels
'12 Wolf Creek 850 TC Coleman Polar Cub 9.2k A/C, 90 watt solar, dual propane & batteries, Maggie Rack
svtkev
i use mineral spirits , its a tip i recieved from a friend who caulks new rvs all day long
Bobbo
Tacswa3 wrote:
You guys recommend a certain caulk for RV use?
I will tell you what NOT to use. Never use anything, at all, with silicone in it.
Bobbo and Lin
JohnG4706
Just a word of caution...
Before spraying any soap solution on the untooled caulking, make sure the caulking is in full contact with BOTH surfaces. If you have any gaps and the soap solution gets in behind, the caulking will NOT adhere. The tooled surface will look great but you'll have a leak waiting.
Good luck.
GMandJM
Thanks for the tip. Will try that or dishsoap next time. The painters tape also is a good one.
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
hooligan
Along the same line: On my previous MH, I replaced the full length decals. Man from the RV dealer body shop did one side, I did the other. He sprayed the area with a weak solution of Dawn dish detergent, easy to move the decal for alignment and then squeegee it in place.
Hooligan U.S. Coast Guard Ret.
2016 THOR Siesta Sprinter 24ST Diesel
2008 SUZUKI Grand Vitara TOAD
1 Pug "Lily", 1 Newfoundland, "George"
1972 MotoGuzzi Eldorado
Horizon170
I use water on my finger to shooth it out. Another trick I use since I'm not very neat is to put down painters tape on on either side of the seam and after I smooth it out I remove the tape and the job looks pretty decent.
There are certain applications where I use $11.00/tube of house gutter caulk/sealer. For instance where I attached the add on to the rear of my RV.
Marvin
2010 Coachman Freelander 22TB on a
2008 Sprinter/Freightliner chassis
1995 Geo Tracker (Toad)
Old-Biscuit
Halmfamily wrote:
downtheroad wrote:
Good tip...for years I have just used saliva....:S
Hope you don,t stick your fingers in your mouth to wet them. :B
I DO!
But usually only good for 1 tube of caulking before I need a break :B
tvman44
Good tip! ๐Ÿ™‚ Thanks.
Papa Bob
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
Halmfamily
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
Tacswa3
Cool, thanks
