How to change a green bottle gas grill to a 20 pound bottle
bigred1cav
14 REPLIES 14
bigred1cav
tenbear wrote:
No problem switching between a large tank and a small one. I usually run my grill off a large tank and carry a couple of small green tanks in case I run out of gas in the large tank. I have switched a couple of times without a problem.
Thank you and all the others
tenbear
2010 Subaru Impreza Sedan
DrewE
bigred1cav wrote:
OK, I got the hose. How about pressure regulation? Is the pressure from the larger tank a problem?
Thanks for all the help
The pressure from a big tank is the same as from a little tankโ€”namely, the vapor pressure of the propane. (Technically speaking, that's only true so assuming the temperature of the propane is the same. A small tank will cool down more quickly as the propane vaporizes, and will thus have a little lower pressure as time goes on than the larger tank, but that's of no practical consequence here. It does matter when trying to run a large appliance from a small tank.)
IAMICHABOD
Not at all,hook it up and enjoy.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
bigred1cav
mowermech
tenbear wrote:
While you are at it, you might consider an 11 pound tank. Same height but smaller diameter. It fits in places the 20# tank won't but is still refillable.
Or, the 5 pound (1 gallon) cylinder (the one I have); about the same diameter as a 20 pounder, but MUCH shorter!
CM1, USN (RET)
2017 Jayco TT
tenbear
nevadanick
They have the hose that you need in the bbq section at Home Depot.
rhagfo
rjxj wrote:
This may work.
Hose
OR
Male at tank
X2
Works great!
Dtaylor
I have seen them in Walmart
Our Travel Blog
2018 Premier 29RKPR
2014 Ford F-150
SCVJeff
Extend a stay will work provided you have an RV close by. All you need is a hose made specifically for this. Obviously Camping World has them but I have seen them elsewhere was well
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
2gypsies1
It's called 'Extend-A-Stay'. We've always used a bigger propane tank. Less costly and more convenient.
Full-Timed for 16 Years
.... Back in S&B Again
FlatBroke
You can purchase a hosed made specifically for that. Check Amazon and most RV supply stores.
Hitch Hiker
"08" 29.5 FKTG LS
