NEW T&P Relief Valve and it is leaking :H
With WH OFF, water cooled downed....OPEN valve with water supply still on and let it blow thru new valve. Stand back cause water should blow out several feet.
YUMA water and installing new T&P you probably stirred up some scale/debris from inside tank and it is stuck on valve seat
New valve and air pocket established.....T&P should not weep UNLESS normal t-stat/high temp t-stat have FAILED and water temp is 210*F or pressure inside tank is above 125 PSI
