Mountain Towing
GraySwain
The wife and I are about to purchase our first camper. Most likely a 5th wheel. A friend mentioned, since we will be towing in the mountains some, to stay small for weight and maneuverability. Considering the steep grades is a 3/4 ton necessary even for something as light as light as +/-7200lbs? Any and all opinions on towing in the mountains would be appreciated. Not opposed to a 3/4 if we have to but almost certainly not going the diesel route. Thanks
38 REPLIES 38
1320Fastback
Larger isn't for everyone but one thing I love about a diesel in the mountains is the power and engine braking. My experience with mountains is the California Grape Vine, Alpine east of San Diego, the 17 mile grade in the desert heading to Las Vegas where air temps will be 90+.
None of these require but one gear shift out of overdrive and going down hill leaving it in overdrive even at 6% grade it still slows by itself without use of the brakes. Can only imagine a Diesel truck that isn't 27 years old would only be better ๐Ÿ˜‰
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
memtb
You will never regret going with at least a 3/4 ton. Itโ€™s pretty difficult to get too much truck. Also, if you actually do quite a bit of mountain towing.....you would โ€œvery quicklyโ€ learn to appreciate a diesel. Obviously, this is MO......If you went 3/4 or 1 ton and diesel, could easily move up into a larger more comfortable 5er. Of course, larger....is not for everyone! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
ACZL
IdaD wrote:
I'd get a SRW 3/4 or 1 ton. More truck for similar money, and they will tow a lot nicer than a half ton. Only downside is a rougher ride and, if gas, poorer fuel economy. It also gives you the option of getting a larger trailer in the future without having to change tow vehicles too, which would save you money and hassle.
I 2nd this statement.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Grit_dog
Navigator
Navigator
^ Turns out you really weren't too off base, just thinking ahead! By the time you posted this, the OP specified dry weight and a TT.
Anyway his post was about towing in the mountains and what to expect, mainly.
Bottom line, same setup required basically if you're towing flat as a board across Kansas or in the mountains. TV capable of the size of trailer and some good trailer brakes mixed with common sense.
Specifically though, and admittedly not on the OP's radar, but since the query is about best way to handle the mountains, a (gasp) Diesel with an Exhaust Brake IS heads and tails better and more comfortable towing experience once you're roller coaster towing. Period.
You can absolutely tow safely with a gasser, but how comfortable do you want it to be?
It's like the difference between a push mower and a rider. Both will do the job safely. Both will leave the lawn looking good when you're done. 1 will require more effort and less comfort.
"Aint no mountain high enough....aint no valley low enough...."
Can't sing that song in a gasser, lol.
steelhunter
steelhunter wrote:
For a 7200lb trailer a 3/4 is an
imperative under any circumstances.
I misread Grayswain's post.
What I stated is incorrect.
Apologies to all.
steelhunter
wing_zealot wrote:
The best thing for you to do is to read up on towing and tow vehicles so you can understand all the variables that go into this question. Start here Clicky
For instance "For a 7200lb trailer a 3/4 is an imperative under any circumstances." My 1/2 ton will handle a fully loaded 8500 lbs fifth wheel without a problem, and still have room for 625 lbs of passengers and gear; all within all its manufacturer's ratings. Lots 1/2 tons could not. So "Imperative under any circumstances" is flat out wrong. Its all in the details, hence, the need to read the clicky.
I was mistaken. My apologies....
happy2rv
There may be a combination of 1/2 ton truck and 5th wheel trailer that remains within the truck's weight ratings, but both the truck and 5th wheel will be the exceptions, not the rule.
If you already have a 1/2 ton and don't want to upgrade, you will have to work within its numbers. Personally I would lean toward a travel trailer instead of a 5th wheel in that case. As already indicated, much more of the overall weight of a 5th wheel rests on the truck than the weight of a travel trailer.
If you don't already have the truck, I'd recommend selecting a truck that works for most RVs in the class you're looking for. This provides the opportunity for future upgrades.
Whatever you decide, I agree with others who already posted that you should study the weight ratings involved and understand them. It's great to get advice and people's personal experiences, but without knowing the parameters involved you can't evaluate the usefulness of responses. To be clear, all 1/2 ton pickups aren't created equally. Neither are 3/4 or 1 tos. Many, most?, 5th wheeler's don't fall within the weight ratings of many, most?, 3/4 ton trucks.
You will see people post here that they tow 70000 lbs with their Tacoma or Colarodo and you will see others say an F350 is overloaded with a feather pillow in the bed. The only way to determine your truck's capacity and ability to tow a given trailer is to run through the numbers. You may decide towing at or even above the maximum capacity of a vehicle is ok, others have. I won't comment on the merits of that decision, but I do suggest you make an informed decision.
2018 Forrest River Salem Hemisphere 282RK - 2017 RAM 1500 TV
Previous RVs and TOADS
2004 Fleetwood Bounder 32W on WH W20
2000 Four Winds 5000 21RB
1986 27' Allegro
TOADS
2005 Ford Ranger XLT 2WD
2004 Suzuki Aerio
1988 Chevrolet Sprint
Hammerboy
gmckenzie wrote:
Also, be wary of jumping to a 3/4 ton diesel. Payload on some of them is barely 2000 lbs (the same as my half ton). And while I do think a 3/4 ton diesel will tow better than my half ton, if both within limits, I'd not want to move to a 3/4 ton and be disappointed in the payload. Gas 3/4 ton typically have 500 or so more payload than a diesel comparably equipped.
New trucks, like the 2020 GMC HD, have thrown this out the window.
While that may be generally true it's not always the case. Some diesels have a higher GVWR than their gas counterparts. Mine for example has #500 more than my buddies newer '14 (same generation). The '20 GM's I believe have even more to where the gas and diesel are almost the same payload (don't quote me on this ๐Ÿ˜‰ Also I will run out of GVWR long before my axle ratings run out wear as the 1/2 gasser may be the opposite and run out of axle rating before reaching its GVWR especially with a fifth wheel adding all the weight to the rear axle only.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
time2roll
Towing in the mountains in and to itself is not a big deal as long as you do not make a race out of it. Allow extra time and enjoy the ride.
ppine
3/4 ton truck or more.
It can be gas, but why not buy a diesel and be on the winning team?
GraySwain
Ok to specify a bit better. Yes, 6800-7500 would be dry weight. Looking in the 26-30tt range. Also, I have plenty of towing experience. And Iโ€™m aware of payload and towing capacity. However, I have no experience towing in any environment with major hills/mountains. Iโ€™m aware of using the gears on descent instead of constantly riding the brakes. Thanks for all the responses.
IdaD
2015 Cummins Ram 4wd CC/SB
time2roll
Is that 7200 dry or GVWR for the 5th wheel trailer? I have been pulling my 7880 GVWR 5th wheel over every mountain I can find for the last 15 years with my old F150. No issues, none. Properly equipped I see no issue with a 150/1500 truck. Most on the lot are NOT properly equipped. You must look very closely at options and the door sticker to know you are getting the right equipment. The dealer/salesman does not care. Watch your payload rating. Many people are more comfortable in a larger truck and that is OK too. Since you are spending money it is not a huge leap to go 3/4 or 1T-SRW.
TurnThePage
The 7200 lb part is no big deal. The 5th wheel part is. You should expect at least 20% of the total 5th wheel weight to be resting in the bed of the truck. That uses up truck payload. Most half ton trucks just don't have the payload to handle it. Remember that passengers and other stuff in the truck also count against your payload.
Any new pickup rated for that weight will have the power to drag it over the mountains.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
APT
Since this is your first RV, I assume 7200 pounds is a dry weight estimate of some RVs you have found. There are many half tons that can pull that weight, but you need to look at all the truck specificatinos not just tow rating.
For a bumper pull, you will be closer to 8k loaded with 1000-1110 pounds of TW. If that is a 5th wheel, then I estimate that is closer to 1600 pounds of pin weight plus a 250 pound hitch in the bed. There are not many half tons that can support 1850 pounds of pin weight plus other gear in bed and people in cab. There are some more that can support 1100 pounds of tongue weight plus bed full of gear and cab, but that is borderline.
Since you mention mountains, then a forced induction engine will perform better than naturally aspirated. Fuel type matters less than torque per $ you want to spend. Are you willing to have the engine turn at 4000-5000rpm at times? If not, get forced induction.
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
