โApr-23-2015 07:27 AM
โApr-23-2015 08:18 PM
mowermech wrote:WyoTraveler wrote:
In 1996 I drove into an RV dealer in southern CA and said I was interested in buying a small TT. The salesman asked me "is that your 1/2 ton PU"? I Told him yes but was interested in the 16 ft TT in the lot. The salesman responded "I don't have anything in the lot that your 1/2 PU can safely tow". Times have changed. They are so desperate for sales they would have sold me a 40' TT and wished me well.
That salesman was, IMO, a fool. You would have been fine towing a 16 foot TT with a half ton pickup. I base that statement on personal experience, having towed a 16 foot camp trailer from Greybull, WY to Tucson and back with a Ford E150 Club Wagon, using a standard receiver hitch with no WDH or "sway control". We frequently took it to Medicine Lodge Campground, as well.
In fact, I towed a 19 ft. TT with that same Club Wagon from Great Falls, MT to Wood Lake Campground in the mountains above Augusta, MT. However, when I towed the 19 foot trailer with the Jeep Wagoneer, a WDH was an absolute necessity, to level the Wagoneer. No sway control was used, though. Our favorite trip with that rig was across Roger's Pass to Copper Creek Campground near Lincoln, MT.
It bears repeating: A properly built, properly loaded trailer, being towed by the proper vehicle, using the proper tires, WILL...NOT...SWAY!
If it does, something is WRONG! DO NOT attempt to "fix" it using some gadget to dampen the sway. FIND the problem, and FIX IT!
Do this for YOUR safety, and the safety of others.
โApr-23-2015 07:43 PM
smkettner wrote:Kennedy64 wrote:
Dad said the sway was slightly better but he would never attempt the e-way again.
e-way? This hitch? http://www.fastwaytrailer.com/shop/e2-hitch/
Looks weak to me. Or something else?
Or was that short for 'easy way' as in some short cut?
โApr-23-2015 07:38 PM
โApr-23-2015 05:53 PM
DavidP wrote:Terryallan wrote:DavidP wrote:
Could be too many things to list but I would look first at trailer suspension as well as not enough tongue weight. A trailer should not sway even if there is NO WDH installed. A properly installed WDH with sway control helps prevent sway from occurring and control it if it does. Adjusting the WDH to deal with sway is just masking a problem. I would look at those two things and go from there.
Actually a properly setup WDH returns steering control to the driver. It may not technically be sway. But a light front axle will make the driver lose control because of the light steering. Returning steering control by replacing lost weight to the front axle will in most cases eliminate the feeling of sway. That is what a WDH does. It does not prevent sway. But eliminates the main cause.
I know what a properly installed WDH does and the importance of it. My point is a properly loaded trailer should not sway with or without a WDH in place. A WDH does not eliminate the main cause of sway and will only mask the real problem which is exactly what I said in my original post. He needs to find out why the trailer is swaying, fix that while at the same time properly set up the hitch.
โApr-23-2015 04:25 PM
โApr-23-2015 03:19 PM
โApr-23-2015 01:54 PM
โApr-23-2015 01:32 PM
โApr-23-2015 01:10 PM
โApr-23-2015 09:50 AM
โApr-23-2015 09:20 AM
โApr-23-2015 09:16 AM
โApr-23-2015 08:49 AM
โApr-23-2015 08:45 AM
โApr-23-2015 08:44 AM
