โOct-03-2022 05:28 PM
โOct-04-2022 05:42 PM
Mayor30 wrote:
You can't use the diesel pumps unless you have an auxilary tank. The high speed nozzles are bigger than the filler on your truck. I have a 40 gallon aux tank in the bed so I can use them.
โOct-04-2022 04:47 PM
โOct-04-2022 04:11 PM
Mayor30 wrote:Lantley wrote:You can't use the diesel pumps unless you have an auxilary tank. The high speed nozzles are bigger than the filler on your truck. I have a 40 gallon aux tank in the bed so I can use them.ford truck guy wrote:
Like many already stated, when I am traveling into area's I am not familiar with I use Google Maps ahead of time to check things out... I usually have an idea of how far I will go and how far I can go before needing to fuel
Looks like you have a diesel tow vvehicle. Finding places to fit is much less of an issue because you can use truck stops a diesel islands at convenience stores.
Finding places to refill with gasoline is a much bigger issue vs. diesel
โOct-04-2022 03:59 PM
โOct-04-2022 03:58 PM
โOct-04-2022 03:52 PM
Gdetrailer wrote:Grit dog wrote:
You apparently have it bad there in PA. Hard to find LP and diesel?
How hard is it to get non ethanol, av gas and race gas?
I do live in a very rural area, closest small city is 25 minute drive one way, larger metro area is 1 hr drive one way.
Non Ethanol gas?
Nope, even though "Gas buddy" says I can, in reality the gas stations that is local to me that Gas buddy says sells it, doesn't so don't depend on Gas buddy as it is wrong.
Can't buy Non Ethanol gas in bulk, if I wanted to pay $20 for a single pint bottle for lawn mowers, sure but I am not paying $80 per month in fuel just to trim my yard.
AV gas?
Nope, not available to the general public, ALL small airports near me that have AV gas have it LOCKED behind fences so you must contact the airport manager to get access and unless you have a valid "tail number" the airport managers will not sell it to you.
Race gas?
Nope, not available to general public, the stations which are close to a popular dirt track (which is one of the World of Outlaws circuit) that have it will only sell race fuel to you IF you have a valid entry pass for that day of the race.
Reason why I know these things is I asked local fuel vendors back in 2011
โOct-04-2022 03:26 PM
Actually it can be a draw either way.
I have noticed there are far fewer fuel stations that have gas AND Diesel and the ones that do have both typically have far fewer pumps for Diesel.
I know myself with having a Diesel tractor how painful it can be getting Diesel at times.. I am sort of lucky to have a small Mom and Pop gas station 2 miles away that serves up Diesel on two of their 6 pumps and "off road" Diesel (no road taxes) on one pump. But in my nearest city, most stations have zero Diesel pumps and the couple stations that do have it, have one pump in a small crammed tight spot which would be not easy to fit a RV into.
Basically if you have a Diesel rig, you typically have fewer choices on where to fill up. Big truckstop places like FlyingJs are not everywhere.
โOct-04-2022 02:57 PM
โOct-04-2022 01:41 PM
pappy43756 wrote:
Google Earth
โOct-04-2022 01:14 PM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โOct-04-2022 11:38 AM
โOct-04-2022 11:23 AM
HappyKayakers wrote:
The Next Exit. Book form or app. It will identify all RV friendly businesses at each interstate exit.
โOct-04-2022 10:10 AM
โOct-04-2022 09:57 AM
โOct-04-2022 09:22 AM
