โMay-26-2014 06:47 PM
โMay-27-2014 04:20 PM
Harvey51 wrote:
The level of the freshwater tank is a good indication of how much has gone into the waste tanks, unless you are bringing large quantities of liquid refreshments aboard.
โMay-27-2014 04:02 PM
โMay-27-2014 02:34 PM
sharker6 wrote:Well you would really have to have a big bladder to get your feet wet using the stool. You should be able to notice when the slider is submerged!:W
Who needs a sensor? When your tank is full your feet get wet. Same with the grey tank and the shower.
โMay-27-2014 12:49 PM
โMay-27-2014 12:33 PM
โMay-27-2014 11:48 AM
โMay-27-2014 09:45 AM
โMay-27-2014 04:36 AM
โMay-27-2014 12:31 AM
โMay-26-2014 09:58 PM
โMay-26-2014 09:15 PM
โMay-26-2014 08:13 PM
โMay-26-2014 08:00 PM
โMay-26-2014 07:55 PM
Tom/Barb wrote:dave17352 wrote:
If you use your rig a lot you will pretty much just know when it is getting full. But if nothing else when it gets full you will know when you flush. It is a pretty simple system. It may burp a little when you flush when it is real full. Eventually you will actually see the contents coming up the 3 inch line, hard to miss. Of course you want it to be at least 2/3 full when you dump so there is enough liquid to get rid of all the solids. Keep in mind the worst than can happen is you could end up with a little in the bowl. Not a crisis.
You must not have a flush kit installed.
We hook up the drain hose to the dump station, pull the slide valve for the black tank, allow to empty, then close the slide valve. Then pull the slide valve for the grey tank, allow that water to chase out the black waste in the hose. then close the grey tank valve.
to flush the black tank, we simply hook up a water hose to the flushing fitting and partially fill the black tank then empty again. repeat as required to insure the tanks flushed out.
