โDec-19-2014 07:58 AM
โDec-19-2014 04:13 PM
โDec-19-2014 03:29 PM
Robin1953 wrote:
Here in GA at the park I am in now charges a flat rate based on the size of the tank. It is $25.23 for a 30# tank.
โDec-19-2014 03:22 PM
โDec-19-2014 02:27 PM
2oldman wrote:Most dealers in WV charge a flat rate for filling a tank. In texas most charged by the gallon. Here in GA at the park I am in now charges a flat rate based on the size of the tank. It is $25.23 for a 30# tank.HappyKayakers wrote:Up north and west it's done by gallons.
It's been my observation that not all propane dispensers are trained equally. Some may use a 'standard' weight for your cylinder instead of actually looking at the tare weight stamped on the collar, then adding for the weight of the nozzle and unsupported hose.
โDec-19-2014 02:24 PM
midnightsadie wrote:That was pretty much the standard practice before the OPD valve. This in theory prevented overfilling the tank.
I,ve been told if the tank isn,t being bled off during fill ?it ain,t being done right.
โDec-19-2014 02:22 PM
HappyKayakers wrote:In all the years that I have been having propane tanks filled, since 1984, I have encountered exactly one dealer that actually read the tare weight on the tank and accounted for the nozzle/hose. That was a small operation in Lufkin Texas.
โDec-19-2014 12:11 PM
โDec-19-2014 11:06 AM
downtheroad wrote:
Ours have always been filled by the "bleeder valve" method. When the bleeder starts spewing, they shut off the fill and charge me by the gallon and tenth of a gallon as indicated on the meter. (example: 4.2 gallons @ $2.49 per gallon = $10.46)
Simple enough and works for me.
โDec-19-2014 10:53 AM
โDec-19-2014 10:39 AM
โDec-19-2014 09:25 AM
beemerphile1 wrote:Ron3rd wrote:
...every propane tank I have ever had filled over the last 35 years, whether BBQ tank, RV tank, or whatever, has been filled by opening the bleeder valve and shutting the propane off when the gas starts shooting out....
When liquid spurts out is full. Gas starts coming out the instant it is opened.
โDec-19-2014 09:18 AM
โDec-19-2014 09:13 AM
โDec-19-2014 08:57 AM
โDec-19-2014 08:42 AM
