All depends...I'm going thru this right now. I've had 3 trailers, all with coroplast bottoms. Two were newer and the self tapping screws weren't rusted solid. This last one was hell on earth but I have no choice.
We drove thru a very heavy deluge in late March on I10. The coroplast was screwed every 6-8 inches. We find out water had gotten in under the frame and coroplast soaking the insulation. I usually loosed the screw with a hand socket then use a drill to back them out. Not this time they were frozen in solid.
I eventually cut around the screw heads and popped the coroplast down.
Due to road salt rust I ground the whole frame bed and ground off the frozen heads. Primered and repainted the frame. Changed out the insulation and when it stops raining I will redrill new holes and use a sealant and aluminum flat bar and 3/4 self tapping screws.
This trailer (bought used) must have been driven a lot in road salt conditions. At least I know now whats under the coroplast. Not a fun job...
Try one or two screws if the come off easy enough you're home free if not it's your call which method you use.
Ian/Mary/Rusty
wire fox terror
03 Dodge Ram 3500,4x4,QC,
Line X,Hijacker 16K slider,
09 Titanium 32E37RSA
