RV Pump Issues
chrizg
Working on a camper and I am having a issue with the pump. It will not bring water up from the fresh tank. I though it was a bad pump so I replaced it with a new one. When the pump is on, it will only pump a little bit of water when a facet is open. When you close the facet it runs dry and keeps running. Shown in the video linked. Any thoughts? All connections that I can see are nice and tight. When hooked to city water all the facets work like they should. This unit was parked in a campground club and was always on city water.
http://www.youtube.com/watch?v=xwhfwQWOxmg
23 Rockwood 2608BS
22 Dodge 3500 Crew SRW
Old
16 365 Landmark Charleston
06 Dodge 3500 Mega Cab 4X2 DRW B&W
16 Dodge 3500 Crew Limited DRW B&W Aisin 4.10
7 REPLIES 7
Peg_Leg
Check the voltage. That's what happen on mine.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
chrizg
Never mind. Fitting was still loose
23 Rockwood 2608BS
Old
chrizg
Was a loose connection on the underside of the turn off valve from the fresh tank. Thanks!
It is bringing up water from the tank now but air is also coming along and making the facets spit. And thoughts on that ? My 5th does not do that.
23 Rockwood 2608BS
Old
Alfred622
You could have debris in the hose running from the fresh water tank to the pump. Usually the city water supply enters your plumbing after the pump and that is all working. You've replaced the pump. Therefore, it would seem logical the problem is between the pump and the tank. Could a leaf or fabric gotten into the fresh water tank the plugged the freshwater feed? Can you use an air compressor and "blow out" the line from the pump back into the tank? Let us know what you find!!
Alfred
2005 Sightseer with Workhorse, ReadyBrute Elite towing 2003 Honda CRV
Map below shows states where we actually camped.....
memgrove
Is the fresh tank full?
Mike
2006 Chevy 2500 4X4 crew cab Gasser
2013 Dutchmen Denali 311 BHS (Love the trailer HATE the manufacture!)
nevadanick
You have a connection that is not sealed tight and its sucking air. Redo the connections and try again
Merrykalia
One of the low point drains is probably open a little bit? Does the water drain out after a while? That was the problem with our last TT.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
