Sway Question
GusCalifornia
Hi everyone,
I have another question. We are getting ready to make a trailer purchase this weekend. I have of course read about sway. The problem is I keep getting different information about sway depending where I look or who I ask. My salesman, for example, told us that the difference between a 28 ft and a 33 ft would not make any difference with sway. Can that be right? I know his goal is to make the most commission so hard to tell if he is being truthful.
Also - how common is sway? We will be traveling from CA to Michigan and likely further so we will be on long stretches of open freeway for weeks. Is sway something we are going to struggle with daily or is it pretty uncommon?
Just an FYI - I have an expedition with a towing package giving me up to 9,200 lbs capacity
Thanks everyone!
20 REPLIES 20
blt2ski
Moderator
Moderator
A number have said go to 10ply/load range E tires. Will it work or not... Not positive. I switched from 8ply/D tires on a SW 3500 to 10ply/LR E tires. Being as I only had 55-60 lbs of air in the tires, TBH, I did not feel a difference.
With above said, having just bought my first 15 series truck. XT sizes are now into play, appear to be a pseudo LR C/6 ply tire. will swag any LT style tire will be way better than a typical P metric, or the XT P metric. Tread design can also make or break towing handling too.
I'm in the "I should be able to tow trailer with out bars of any sort shape or form" group. You never know when you can loose or have one loosen up. Best to have a trailer that does not want to "fish tail" sway in its own.
Getting buffeted by side winds, trucks passing or you passing them. Should be expected. Any unexpected movement, should be side to side rocking. Or being pushed sideways as a unit. If the truly move separate, you have a problem. Find the reason, fix it!
You may have too little hitch wieght as mentioned. Too little psi in trailer truck tires for the load. Trailer axles V'd vs perpendicular to travel, not parallel. Too soft a suspension/shocks/tire sidwalls on trailer or TV. Too much wieght on one side of trailer. Hitch mounted nose up. ... I could go on. Hopefully one sees my points.
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
philh
Upgrading tires to 10 ply will help a lot. I'm on a much smaller trailer and was surprised how much difference upgrading truck tires did to the stability.
Grit_dog
Navigator
Navigator
It’s hard to explain to those who don’t have experience towing a lot.
But unless the TT is grossly over or under on “expected” tongue weight, it should pull just fine with a capable half ton.
Salesman wasn’t “totally” lying but also not to be really believed as they’re, well, salesmen.
goducks10
I wouldn't worry about out of control sway as much as I'd be concerned about the TT and truck not functioning as one. A heavy long TT with a 1/2 ton may not ever sway out of control, but you could experience more than desired movement when over taking a semi, or being passed by a semi and towing in windy conditions. Also it could be a little tense when needing to panic stop on a corner.
Lots of conditions come into play when towing.
Having to keep both hands glued to the wheel with bigger than normal wheel corrections doesn't make for a fun day of towing.
Like I said you may never experience out of control sway, but the day in day out driving experience will wear on you.
JIMNLIN
AS you have surly discovered by now their are many reasons a combo can have sway... so no one fix works on all combinations.
Other expy owners who are pulling the same length trailer can have input for you so check with trailer brand forums also.
One of the worst bumper pull sway incidents I've seen when I was on the road was a one ton DRW truck pulling what looked like a 25-28' TT. We could guess till the cows came in why the combo was swaying.
Some ideas expressed here can add to a sway issue so use proper equipment and hit the road for a short run and see how the combo is working. Then make changes.
Timmo_
Just because you "can", does not mean you "should".
In my tiny situation (20' Nash TT) has an "advertised" carrying capacity of 2000 lbs, problem is after I add the weight for all my "necessities", I can sneak up to the TT's GVWR of 5600 lbs. Especially if my fresh water tank (42 gallons) is filled (an extra 350 lbs).
After I bought my truck in 2005, I weighed my loaded TT at a scale and discovered exactly how the weight was distributed between all 8 tires. You'll be surprised how the weight of beer, food, clothes, full kitchen setup, and other necessities adds up.
Over the years our RV habits and needs have changed and, just like my waistline, I am sure the combined weight of my TT has increased as well--but not over the truck max towing capacity of 9200 lbs.
I parrot the words of others, if you dial in your rig's weight distribution, there shouldn't be any sway issues. I use the plain vanilla WD hitch setup that's rated for 750lb tongue weight.
Tim & Sue
Hershey (Sheltie)
2005 F150 4x4 Lariat 5.4L 3.73 Please buy a Hybrid...I need your gas for my 35.7 gallon tank!
2000 Nash 19B...comfortably pimped with a real Queen Size Bed
packpe89
Over 30' will catch allot of wind, definitely 3/4 ton truck territory for a long drive.
BenK
IMHO, ask 10 folks for their opinion and you'll get 12 opinions...
There is a lot to it a not just any single item that folks tend to touch/mention, as it may have fixed it for them.
Towing is a system of many, many components/sub-systems/knobs/dials/etc. Plus many WD hitch systems that all claim to solve sway (most do, but they have to be both sized correctly and the biggie...adjusted correctly)
Many will talk about stiffening the TV's suspension. From higher class tires, to higher PSI, to springs, to everything to do with the TV's suspension. All kinda sorta okay, but most just end up as band aides and not addressing the root cause(s)
Will leave it to the others to advise what worked for them, but note that there has been many newbies lead into circular cycles without resolution.
My advice is first view//read up and learn what sway is. Then what the components & their dials/knobs do.
Bottom line advice is: that the goal is to have the TV's front axle returned to whatever your OEM's manual says. Some talk about front fender height, others to front axle load weight...etc.
Then that the trailer tongue should be in the 12%-15% of the trailer's total weight when loaded.
Finally, that the trailer tongue should be level or pointed slightly down after the complete setup is dialed in
Some better FYI video's on trailer sway. First two addresses tongue weighting and where the weight should be o the trailer
https://www.youtube.com/watch?v=i2fkOVHAC8Q This one has an adjustable trailer axle location. What they didnot show is, that if the trailer axle was moved rearwards, it would tow better, but would have a heavier tongue weight. Why higher class TV's has higher rear axle GVWR's
https://www.youtube.com/watch?v=w9Dgxe584Ss
https://www.youtube.com/watch?v=GWJ4Iy6ek24 this one talkes about WD hitches
Good luck and post back on how it works out for you
Edit...many will say weight ratings are not that important, but I'm not one of them. Sure you can go over, to even way over, but I'll not ever recommend that.
Just note that all things designed/engineered is for the worst day out there when Mr Murphy crosses your path when you'll need every ounce of safety factor the designers/OEM dialed in...and either you have it spot on or not.
Finally, on this is the drivers experience and knowledge factor. What will you do if/when you encounter that situation? Educate yourself well...
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
pitch
First off sway must be defined. Many call the suck and pull from trucks passing sway. I don't think so.
Many call being blown around by the wind sway. once again no, although sway can be precipitated by either of these
Real sway can be compared to "death wobble". A combination of events and physical characteristics combine into an unstable condition.
Swayis most often induced by being tail heavy and the vagrancies introduced by being unbalanced
Personally just from the information here ,I would say 33' is too long.
Grit_dog
Navigator
Navigator
Aaaand we’re off on another rvnet weight police adventure!!
OP, no one can tell you how stable a theoretical 28-33” trailer will be. And peoples definitions of “sway” vary wildly.
Some think if you can feel the trailer back there it’s swaying and the other end of the spectrum is full on out of control trailer sway.
Sorry can’t give you a solid answer, but there will be plenty more “advice” forthcoming on this thread I predict.
bikendan
No way would I tow a 33ft trailer with a soft suspension Expy.:E
Especially with someone new to towing a long TT and on a trip so long,and over the Rockies.
OP, you need to forget that bogus towing capacity number and focus on PAYLOAD capacity and the loaded tongue weight of either trailer.
Dan- Firefighter, Retired:C, Shawn- Musician/Entrepreneur:W, Zoe- Faithful Golden Retriever(RIP:(), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
goducks10
33' unless it's a really light TT is too long for your EX.
The longer the TT the more side surface to catch wind and if it's heavy that will only add to sway with the EX.
Just because Ford says the Ex can tow 9200 lbs doesn't mean you'd want to. Normally most tow ,much lighter TT's than what their tow vehicle is rated for.
You don't mention the weight of the TT's. IMo you shouldn't go over 6,000 lbs loaded with the EX. Go short with 25'-28' max.
Check the payload rating on the door jamb. Make sure the tongue weight is 12%+
TurnThePage
1A) Make sure your current equipment is up to snuff: Essentially, inflate your tires to the correct pressure for your vehicles. For towing, that isn't the value listed in the door jam either. If you don't know that information, you can simply inflate your OEM (or equivalent) tires to the max pressure listed on the side of the tire (on both the trailer and the tow vehicle). Other safety equipment like a trailer brake controller should be installed.
1B) Make sure your tongue weight is at least 10% of total trailer weight. Even more would be preferable.
2) After those first two steps, you can then consider adding anti-sway and weight distributing hitches. There are a wide variety. Your vehicle should tow fairly stable before even adding one.
3) One you've performed those other steps, you can fine tune to your hearts content. Many people upgrade their tires on their trailers right away. Many people driving half ton tow vehicles upgrade their P metric tires to LT rated tires too. People also often add air bags to enhance the rear springs of their tow vehicle. Lots of fun ways to spend your hard earned dollar.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
MarkTwain
GusCalifornia wrote:
Hi everyone,
Thanks everyone!
First, throw away the new tires on on your trailer or replace the old tires if trailer is used. Replace with TL 10ply tires on both the trailer and truck. Then buy a good sway control set up ie Reese dual cam. Great sway control for my 32' trailer. It is also important you watch when you load your trailer and try to keep your load evenly balanced throughout your trailer.
