โFeb-02-2023 08:20 AM
โFeb-04-2023 05:20 AM
Is the dryer vented to outside? if so, has it been cleaned?
Have you checked the washer drain vent?
Can you do a smellcheck to see if the clothes smell bad after the wash cycle or the dryer cycle?
Do you have a lot of iron in your water? The bacteria and sulfur oxide can make it smell bad. perhaps add a particle and carbon block filter to your supply line and might fix the issue.
Different location???? Different water supply.
Yep and all my HE appliances are awful. They're high efficiency either because they use less water, spin less and slower or in the case of my dishwasher don't dry properly because the element is weaker and doesn't stay on long. All these things lead to smells. Water remaining in any appliance will lead to mildew or lingering sulfur smells. Modern appliances simply do not work as well as older models for the sake of efficiency.
Stupid me I bought a bucco bucks Bosch dishwasher for the house, 4 yrs later a repairman asks how often do you run this? I said we have a son, his bride and newborn living with us as they find a house, and I do daycare for the grand kids, so 2 maybe 3 times a day. He stated MODERN DISHWASHERS ARE ONLY DESIGNED TO RUN 3 TO 4 TIMES A WEEK!!! I wore it out!! Energy efficient means less water, smaller motors, smaller heating elements, ETC. Pretty sure it's the same for all modern appliances.
With our HE washer I often have to wash clothes twice to remove dirt/odors, or use a heavy perfumed detergent and softner(not going to happen). I also have to wipe the water out of the rubber door gasket to avoid moldy stagnant water sitting in it, and removing the detergent tray and spraying with a bleach & water solution to prevent mold in that dark moist area.
But hey we we're saving the planet even though we are having to run the appliance twice as often to get the results of the old ones running once. Truly I don't understand it, but what are the options?
Wipe out every area, spray with a bleach/water solution and hopefully you can get ahead of the smell & mold.
Sorry for the rant, but its my challenge too.
โFeb-03-2023 03:52 PM
โFeb-03-2023 05:12 AM
Campinghoss@51 wrote:
HE - stands for high efficiency
โFeb-03-2023 02:29 AM
โFeb-03-2023 02:27 AM
โFeb-03-2023 02:23 AM
LMHS wrote:
HE washers, top load and front load, are supposed to have a "cleaning" cycle run once a month (I think Splendide manufacturer says every 30 washes). It should have come with the directions for your washer. My HE top loader has a "clean" cycle (just add bleach) just for cleaning. I find it easier to run the clean cycle on the 1st day of every month. Otherwise you can buy a product called Affresh and run that in a cleaning cycle OR a short cycle (NOT a fill and dump cycle but an actual wash cycle). On a front loader, you MUST wipe out the backside channel of the flange around the door as it will smell nasty and can also make your clothes smell. You may not notice your clothes smelling if you use a heavily scented fabric softener or detergent (do you smell like "Eau de Gain" or a similar detergent/softener?). Don't forget to clean the detergent/bleach/softener dispenser cups.
โFeb-02-2023 07:23 PM
โFeb-02-2023 04:48 PM
โFeb-02-2023 09:24 AM
โFeb-02-2023 09:14 AM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โFeb-02-2023 09:06 AM
Bud
USAF Retired
Pace Arrow
