Would this be safe?
mgirardo
I am currently experiencing a problem with my converter/charger. Unfortunately at this hour I can't get a replacement and need to be able to keep my full fridge running. I can run the MH's engine to charge the house battery, but I don't want to do that overnight since we are in a campground.
Would it be safe to connect a battery charger to the house battery to charge the battery while the MH is on shore power?
Thanks,
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
9 REPLIES 9
mgirardo
Thanks for the follow-up all. The charger didn't actually help. The battery ran down over night. I'm guessing the battery was in such poor shape it would not take a charge from the charger and it kept the converter/charger from working as well.
I replaced the battery and all is well now. We are almost 2 weeks into a 6 week trip and this the the 3rd issue we had with the MH.
I don't have reliable internet access where we are, so I grabbed our packet with all our manuals, etc and went to a reliable internet source. I knew we had an IOTA DLS 45, but for some reason we also had a Progressive Dynamics manual for the PD9200 series charger/converter, so that really threw me for a loop
I guess someone with a Jayco RV is missing the manual for their PD9200 series converter/ charger.
Thanks again,
-Michael
Michael Girardo
wa8yxm
There is little difference between a SMART charger and a modern 3-stage converter.. The major difference is you may have to restart the charger manually from time to time, where as the converter does that automatically.
And please note the key word MAY in that sentence, implies it might not be needed as well.
rjf7g
I ran a jump pack in parallel with my house battery for weeks without any issues until I could have my charger replaced. It worked like a champ!
1999 American Cruiser Class B
2006 Palomino Puma 27FQ Bunkhouse
2007 Gulfstream Innsbruck 36FRS Park Trailer
RoyB
Be sure to check the fuses associated with REVERSE POLARITY - might be all that is wrong with your converter. Usually one hooks up the batteries in reverse which blows those two large fuses...
I also have a in-line fuse real close to the battery bank but the newer trailers I think have a auto reset circuit breaker there now...
We carry a 40amp smart mode BLACK and Decker VEC1093DBD just to charge our battery if we need to. A great PLAN B...
If you have ad your batteries disconnected before starting to have problems with your converter you might want to check your battery polarity. Find the words NEG or the SYMBOL '-' and make sure this is the cable going to the trailer frame ground...
Since you said you have been charging your battery by running the MH motor you are problem ok I would check anyway haha...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
SCVJeff
newman fulltimer wrote:
yes but flip the breaker on the converter off or unhook it
shouldnt make any difference. It's likely diode isolated, and is akin to paralleling chargers that several around here do
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
newman_fulltime
mgirardo
Great thanks! I appreciate the quick responses.
-Michael
Michael Girardo
Ductape
No problem at all. Just mind your polarity as always.
49 States, 6 Provinces, 2 Territories...
accsys
Absolutely, that's what I would do.
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
