2 66 lb batteries
AStinker-
Listed below are 2 batteries that are the same weight but each has a different Ahr rating. The Ahr and weight came from spec sheets.
235 Ahr / 66.0 lb = 3.56 Ahr / lb
240 Ahr / 66.0 lb = 3.64 Ahr / lb
Hypothetical question:
If you had to buy batteries based on this single fact which is the better buy?
19 REPLIES 19
Matt_Colie
Juda's Priest Guy....
You are looking at a 1.8% difference. The experimental error on the test is usually more than that. So,
Pick Either:
The one from the dealer that will give you better service.
The cheaper one and live with that dealer service.
This is what I did all the time for owners of expensive boats before the depression shut us down. So just follow your brain.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
doughere
Whichever store was nearer.
Doug
EsoxLucius
AStinker- wrote:
What I'm trying to understand is how weight and Ahr and Ahr / lb can be used when making battery comparisons.
It can't. Weight is one factor, 20 hour ampere hour rating is another, as is price, manufacturer reputation, warranty, shipping costs, dimensions, date code, and charging profile. Remember, the capacity rating made by a manufacturer is based on industry accepted standard procedure. However, there are still differences in the individual results and a difference in capacity rating of 2 percent is likely inconsequential for batteries that weigh the same. There are other, and perhaps more important, factors to consider when choosing batteries.
2013 LTV Unity MB Theater Seats
635 watts solar panels, 440 AH batteries, BlueSky Solar Boost 3024iL & IPN-Pro Remote, Magnum MS2000 & ME-RC50 remote
Koni Shocks F & R, Hellwig 7254, SumoSprings F & R
2012 Hyundai Accent SE, Blue Ox Aladdin/Patriot
BFL13
AStinker- wrote:
BFL13 wrote:
When it is that close it doesn't matter IMO. More broadly, the weight is useful when you don't know which exact rebranded battery you are buying at Costco or wherever.
I can't find their weights in the spec sheets but they used to show the weights, eg for U-2200s at 232AH and U-2000 at 216 and U-1800 at 208. So when you see it is one of those rebranded at Costco but can't tell which one it is, you need to weigh it and now you know what AH it has. Otherwise you might think you are buying 232AH and actually it is 208AH.
For Trojan it's
T105, 225AH, 62lb
T125, 240AH, 66lb
T145, 260AH, 72lb
My Interstate GC2-XHDs, 232AH, 67lb
Between the XHD and the T125 it seems the T125 weighs less per AH so different brands affect comparisons, but still in the ballpark. IE don't make too much of small diffs.
Ok so if I understand you correctly what you are saying is the following 2 batteries from different mfg weight is probably not a factor
235 Ahr, 63 lb
225 Ahr, 62 lb
but the following 2 batteries from these 2 mfg, weight would be a factor
235 Ahr, 63 lb
235 Ahr, 66 lb
so am I understanding correctly?
I would be very suspicious of the 235 at 63lbs label, where my 232 XHDs are 67. We had examples of rebranded batteries showing the wrong AH at the store in a thread a while back.
There may also be a height factor where they make "tall" batts that have different plate per electrolyte ratios ISTR--I suppose that would affect weight comparisons?
EDIT here are some comparisons showing brands, AH, and wts
http://www.evdl.org/pages/gc_comparison.html
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Chris_Bryant
Based on that single fact- buy the one with more amp hours, of course. But you never buy batteries based on a single fact, so not only is the question hypothetical, it is meaningless.
-- Chris Bryant
AStinker-
For Trojan it's
T105, 225AH, 62lb
T125, 240AH, 66lb
T145, 260AH, 72lb
235 Ahr, 63 lb
225 Ahr, 62 lb
235 Ahr, 63 lb
235 Ahr, 66 lb
mena661
X2 You might get a slight longevity edge with the 235Ah one but not enough to make any real world difference.
MEXICOWANDERER
EsoxLucius wrote:
Impractical question: If you had to buy batteries based on this single fact which is the better buy?
There has to be more involved in the decision between two batteries than that.
Let's make this FUN.....A what if...
Those two batteries came from the same manufacturer and the battery with the FEWEST amp hours cost a couple of dollar more?
Bumpyroad
Ozlander wrote:
You really need to kind something useful to worry about.
had a friend years back who when buying electrical devices, always picked the heavier one. ๐Ÿ™‚
bumpy
BFL13
For Trojan it's
T105, 225AH, 62lb
T125, 240AH, 66lb
T145, 260AH, 72lb
Photo in Profile
Ozlander
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
AStinker-
BFL13 wrote:
Did you put the 66.0 there or is the spec 66? If 66, then rounding off could make them the same weight.
The 66 lb came from the spec sheets and I suspect they have been rounded but have no way of knowing for sure. I was originally going to have a 3rd one but its spec sheet was 65.7 lb so I left it out trying to avoid the rounding off issue.
What I'm trying to understand is how weight and Ahr and Ahr / lb can be used when making battery comparisons. Is the higher the Ahr / lb better or is the lower the Ahr / lb better.
pianotuna
Nomad II
Nomad II
Hi mena,
He wants to use only amp-hours as the comparator. This is not a real life exercise. Personally between 235 and 240 amp-hours, it would depend on a lot of other incidental factors, such as price, which battery is newer (check the date codes), and physical dimensions.
Regards, Don
mena661
