2 6v parallel with 1 12v
kfrenette
Hey Guys,
I am new to RVing and I we have just bought a jayco x213. My family and I are doing our first dry camping and I have purchased 2 6v batteries. My question is this, will I run into any problems hooking the 2x6v (already in series) parallel with the 12v. They are different batteries. Should I just keep the 12 as a back up and run the 6v? Any recommendations would be great!
19 REPLIES 19
MrWizard
Moderator
Moderator
yes it can be done
not the perfect situation, but acceptable with 'low' amp loads
lights, fan, water pump, etc..
using an inverter with high wattage loads, is where the difference in battery design and age will have a more noticeable effect
I can explain it to you.
1997 F53 Bounder 36s
Mandalay_Parr
It's not ideal but it will work.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Dennis_M_M
All shall be revealed: The 12 Volt Side of Life
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
skipnchar
It will work but not be efficient. For maximum efficiency all batteries used in parallel should be the same size, power and age. When any of those things are mismatched efficiency drops. Charging may be incomplete and they will discharge faster than optimum. Weaker batteries in the group will drain the stronger ones down to their level.
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
RoyF
I've never done it, but I would certainly want the two 6v in series and the one 12v to have the same voltage reading, or as near the same as you can get as measured by a good digital voltmeter.
