โAug-13-2023 07:15 AM
โAug-20-2023 12:50 PM
โAug-20-2023 11:15 AM
โAug-20-2023 06:37 AM
โAug-19-2023 10:52 PM
โAug-19-2023 02:54 PM
Grit dog wrote:
I realize comprehension is low sometimes on this forum, as Iโm the only one who apparently picked up on you saying your AC blowing 70deg air out of it.
So youโre trading in a trailer with a bad air conditioner for one with basically the same unless you go 50A dual AC but with a working AC?
Even if you donโt want to diagnose why your AC is putting out room temp air, if you can use basic hand tools and reconnect 3 wire nuts back to the same wires, you can fix your problem in about an hour just by buying a new AC.
And you can weather proof the stuff a bit for a bit more efficiency just like youโd want to with any RV. Especially if youโre trying to live in a gray sardine can in some of the hottest weather in the country.
This be like the guy whoโs gonna spend $2700 for 70ah more battery capacityโฆ.why?
โAug-16-2023 12:28 PM
โAug-16-2023 09:51 AM
โAug-16-2023 08:46 AM
Grit dog wrote:
^Iโll defer to you as the expert here. Iโm certainly not. Nor have I ever put a thermometer to one. And it always feels like the air coming out is far more than 20 deg cooler than ambient (in the camper of course)
Although apparently it is not. Must just feel that way when itโs 95deg out, camper is sitting in full sun, obviously isnโt keeping up with a thermostat setting in the low 70s but feels ice cold if youโre standing right underneath it.
I would have guessed more like 30-40 deg.
So basically thereโs nothing wrong except for the OP having a normal (albeit marginal) setup for the extreme Summer heat and humidity in the Deep South.
Well then I agree, if thatโs the plan, to cool the inside of a tuna fan in a sauna, go 50amp, dual AC and donโt look back.
Or try to find some shade for less money than the large amount of $ youโll spend trading a Covid era purchased newer camper on a brand new more expensive one.
I spent years, sometimes working away from home for months at a time, but in the same location generally long enough to rent an apartment or old house with a couple guys on the job. As much as I thought a RV would be the ticket, it never penciled out.
The only way it would pencil out was if I would have had to hotel it. Then a RV would be a little cheaper.
Just something to think about.
โAug-16-2023 06:22 AM
โAug-15-2023 09:17 AM
โAug-15-2023 09:02 AM
โAug-14-2023 03:44 PM
โAug-14-2023 01:36 PM
โAug-14-2023 11:36 AM
Hondo99 wrote:wa8yxm wrote:
Many RVs simply do not have enough A/C.. But when you say you checked topside. Did you remove the covers and look at the FAN side of the evaporator coils.
Most A/Cs blow air through the condenser so any "Crud" that builds up on the condenser is hidden where you can't see it.
Colemans Suck. so you can easily see that they need cleaning. and it's easier to do.
Iโve already tried! Believe me ! Itโs getting traded in over Labor Day weekend, if sales are good ??
