AC is icing up but not cooling
cswinford
Hello,
We have a 15k BTU Colman AC with a heat pump in our Open Range fifth wheel. The unit wasn't cooling so I replaced the capacitors, but to no avail. The compressor is running and the lines ice up but it is not blowing cold or even cool air. I've had a mobile Rv tech look at it and he says the unit needs replaced. I thought I'd run it by this group to see if there's anything more I can try before dropping a grand on it.
Thanks in advance!
Safe Travels!
Chad
See my fulltime RV blog @ http://longlongwaytotipperary.blogspot.com/
14 REPLIES 14
dougrainer
Yes, we do get air volume inside but it's not cooled.
Yes, the compressor was running before changing the capacitors but it wasn't running very strong.
Yes, this is a ducted unit.
The lines are icing (not the evaporator).
OK, In 37 years I have never heard of or have seen a Compressor that was not "running very strong". HOW would you determine that??? Especially a novice. Not running strong can mean that you have lost your charge and the compressor is NOT having to pump the full system. Losing a charge will cause certain areas to freeze up, especially if you have a blocked area. That is why you NEED a amp draw of the compressor. Doug
Denny___Jami
Just a guess but I'm thnking the icing is taking place at the change over valve because it's not completely changing from the heat to cool mode. Heat pumps shift back to the heat mode when turned off, the changeover valve is energized when the system calls for cool. If that's the case the valve would have to be replaced, I would replace the unit and I know how and have the equipment to replace it.
Denny
2013 F350 SC DRW 6.2 V8 4.30 gears Air Lifts
2003 HitchHiker Premier 35FKTG 215/75/17.5 Goodyear G114 Tires
cswinford
dougrainer wrote:
1. Year and MODEL of the RVP HP
2. Do you get ANY air volume inside?
3. Was the Compressor running before you changed the Capacitors?
4. Is this a ducted unit?
5. Icing----Lines or the Evaporator? Doug
@dougrainer
Thanks!
Safe Travels!
Chad
dougrainer
YC_1
You can turn the heat pump mode on for a few minutes to dry out the condenser. Florida is full of humidity and sometimes I have to do that on one of mine. I do keep the condenser very clean. I have replaced the sensor as well.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
Dave_H_M
OP said the lines are icing up0. Lot of folks addressed the evaporator.
Exactly what is the symptom? Where is the frost?
RoyB
My off-road POPUP trailer setup will do this especially when running all night long at an electric camp site when it is very humid outside...
I seem to help things by making sure I have a portable fan running inside the trailer...
In my case being a POPUP I'm sure it has something to do with my fabric walls and plastic covered windows not insulated enough from the outside...
Just something else to watch for on those very humid nights...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
wa8yxm
Icing is caused by one of two things. Reduced air flow due to use of LOW speed and clogged filters.. But from the sounds of it this is NOT your problem for you have cleaned the filters.
Low refrigerant. I have seen ONE TIME it was not low refrigerant in my life... Several where it was.. This indicates a leak in the supposed to be sealed system so you will need professional help if this is the cause.
j-d
Not a bad reply in the bunch!
Here's the Text Only of Chris Bryant's A/C Tuneup Thread. It's been moved around so much that the links to the pictures don't work right.
I was able to find the Diagram Chris drew and refers to:
Front of RV is on the LEFT in the Diagram. You need to remove the decorative cover then enough internal shrouding to access the Blue Indoor Coil, properly called Evaporator. The Red Outdoor Coil, the Condenser, should already have decent access, once the Cover is off.
Chris had a pic of Freeze Sensor, which I can't find, but it's on the forward side of that Blue Coil.
I plan to clean our Coleman Mach 15 today and I'll get a couple pix. It's straight cool and non-ducted so no Freeze Sensor or Reversing Valve.
When it's dirty, the Evaporator Coil is now insulated, and water that should drip off, Freezes. If Refrigerant charge is low, then the reduced amount expands right at the Evaporator Inlet. That overcools the one area, enough that condensate freezes. The frozen area expands because the ice is an insulator and prevents air flow across itself.
But please heed Chris' words: Not Usually Low Refrigerant!
If lines are icing, compressor is running and there's at least some refrigerant. I suppose the Reversing Valve that switches unit from Cool to Heat could be in trouble but let's not jump to that conclusion.
See if you can inspect both coils, clean as needed, and get back to us. Just remember, BOTH, not just the Condenser you can see in back right away.
Ranger_Smith
Freeze up is generally 1 of 3 things:
1. Freeze sensor not located properly
2. Coil dirty and or diminished air flow or air leak . . . Go on roof remove cover. Remove evaporator cover . . .
Clean coil
3. Low refrigerant.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
rjsurfer
smkettner wrote:
For icing up:
Assuming you have a wall thermostat you should have a freeze sensor that needs to be right up on the evaporator. These are notorious for falling away due to poor installation.
Secondly while you have removed all the interior trim to find the freeze sensor, check that the divider that separates the air in and air out plenum is well placed and sealed to prevent recirculating of chilled air.
But I find it odd you say it is iced up and the tech says a needs a new unit. Are you sure it is iced up? Usually they will blow cold air for at least 20 minutes before the ice interferes with cooling.
Pay attention to this reply.....all good advice especially about the freeze sensor ๐Ÿ™‚
My poor old Dodge 2500 has a bad freeze sensor but it's located deep under the dashboard, impossible to get to without 5 hrs of labor.
So when its humid out and the coil freezes over we just shut the AC off and in a few minutes all is well again when the ice melts ๐Ÿ˜•
Ron W.
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
time2roll
For icing up:
allen8106
Make sure the fan is set to high speed. If it`s not the evaporator coil might be freezing up.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Gulfcoast
I'd get a new one instead of spending a grand on the old one.
RV'ing since 1960
Dodge Cummins Diesel
Mega Cab
Jayco Travel Trailer
