โFeb-26-2017 08:56 AM
โFeb-28-2017 02:34 PM
โFeb-28-2017 01:41 PM
โFeb-28-2017 06:30 AM
NJRVer wrote:
Batteries for adult toy.
I guess I'll take my mind out of the gutter after seeing that title.
โFeb-28-2017 06:18 AM
โFeb-27-2017 04:16 PM
I suspect you won't get any satisfaction going over to the Trojan hydrolink thread.
I just went there and boy did you disappoint me.
bumpy
โFeb-27-2017 04:15 PM
โFeb-27-2017 04:10 PM
โFeb-27-2017 02:20 PM
โFeb-27-2017 10:10 AM
โFeb-27-2017 05:48 AM
I ran a pair of group 27 "Marine Deep Cycle" batteries using a manual battery switch. 1, 2, , BOTH and OFF. Battery one was the engine battery, 2 for all the 12V loads (power anchor windlass on the Chriscraft).This is my setup. Once under way after using Batt 2 I switch to BOTH to give Batt 2 a charge.
โFeb-26-2017 04:04 PM
โFeb-26-2017 04:03 PM
red31 wrote:
the point is temp comp for long life, this prevents over and under charging.
under charging leads to sulfate, under charging leads to additional battery maintenance. Flooded require it also for optimal life. Solar provides this easily. lead acid is lead acid
so just how un optimal is battery life of Deka's AGM if charge with a smart charger set to their recommendation without temp comp? precision please!
โFeb-26-2017 03:48 PM
โFeb-26-2017 02:34 PM
