Black tank bound up.
The_Kunkels
Our black tank won't pump out. The fellow in the park said he got nothing out. When ya look down the toilet it is not empty. Thanks.
The Lord loves you so don't leave home without Him.
Safe travels to all.
God Bless โ€
23 REPLIES 23
MitchF150
What do you mean by "pump out"??
Don't you just hook the hose to it and open the valve and gravity takes over??
If you've just left it open the whole time you've been stationary, then it's just full of solids and that's your problem??
With an RV tank, you are supposed to keep the valve closed until it's full, and then open the valve. The liquid in the tank is what moves the solids out.
If your solids are now dry... Well, you'll have to fill it up with water and let is soak for a bit.. Open the valve and see what comes out or not..
It ain't like a home sewer or even a home septic tank...
Good luck!
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
rockhillmanor
The_Kunkels
The tt is stationary. 35' Hornet Keystone.
God Bless โ€
John_Joey
Very possible your black tank valve is stuck closed or you have a blockage in front of it. Best to call the RV service place and let them do that job. They will tell you if your valve is good and if it is they have a tool that will blast the blockage out. Most of the time it is just a length of PEX with a shut off valve on it.
Thereโ€™s no fool, like an old fool.
Colo_Native
You could try a bag of ice and drive around while it melts heard that work. I have not tried myself
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
jplante4
No mention of your rig, but if it's fairly new, the punch outs for the tank penetrations could still be in the tank and one managed to work it's way into the outlet. The fill it up and drive around will solve this temporarily, but the next time it's empty, beg, borrow or steal a boroscope and have a look around.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
dons2346
Trackrig wrote:
Add water to it so it's half full or a little more and then go. Take it for a drive with lots of vraking and corners so the water sloshed it all loose and then dump it again.
Bill
This is where I would start
DiskDoctr
We've read that adding a little dishwashing detergent helps things slide out the pipe ๐Ÿ˜‰
Trackrig
Add water to it so it's half full or a little more and then go take it for a drive with lots of braking and corners so the water sloshes it all loose and then dump it again.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
