Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
MELM
Click here to go directly to Updates.
Update Number 1 Nov 23, 2006
Update Number 2 Dec 5, 2006
Update Number 3 Jan 10, 2007
Update Number 4 Jan 19, 2007 - Recall Instructions - click here: Dometic Recall You need your model and serial numbers.
Update Number 5 Feb 13, 2007 - Added links to new info on the NHTSA website including the info/form for claiming reimbursement for a failure. These are at the end of the post below where all the updates are posted.
Also, edited the below Recall to include the change made prior to the Dec 5 update showing the proposed remedy.
Below is information from the NHTSA website on a recall of certain Dometic refrigerators. This recall is in its very early stages, and there is no resolution in place as of Nov 1, 2006.
From the NHTSA website:
Dometic Recall NHTSA Campaign ID 06E076000
Make / Models : Model/Build Years:
DOMETIC / NDR1062 9999
DOMETIC / RM2652 9999
DOMETIC / RM2662 9999
DOMETIC / RM2663 9999
DOMETIC / RM2852 9999
DOMETIC / RM2862 9999
DOMETIC / RM3662 9999
DOMETIC / RM3663 9999
DOMETIC / RM3862 9999
DOMETIC / RM3863 9999
Manufacturer : DOMETIC CORPORATION
NHTSA CAMPAIGN ID Number : 06E076000 Mfg's Report Date : AUG 28, 2006
Component: EQUIPMENT: RECREATIONAL VEHICLE
Potential Number Of Units Affected : 926877
Summary:
CERTAIN DOMETIC TWO-DOOR REFRIGERATORS MANUFACTURED BETWEEN APRIL 1997 AND MAY 2003: SERIAL NOS.
713XXXXX THROUGH 752XXXXX;
801XXXXX THROUGH 852XXXXX;
901XXXXX THROUGH 952XXXXX;
001XXXXX THROUGH 052XXXXX;
101XXXXX THROUGH 152XXXXX;
201XXXXX THROUGH 252XXXXX;
301XXXXX THROUGH 319XXXXX,
INSTALLED IN CERTAIN RECREATIONAL VEHICLES AS ORIGINAL EQUIPMENT AND SOLD AS AFTERMARKET EQUIPMENT. A FATIGUE CRACK MAY DEVELOP IN THE BOILER TUBE WHICH MAY RELEASE A SUFFICIENT AMOUNT OF PRESSURIZED COOLANT SOLUTION INTO AN AREA WHERE AN IGNITION SOURCE (GAS FLAME) IS PRESENT.
Consequence:
THE RELEASE OF COOLANT UNDER CERTAIN CONDITIONS COULD IGNITE AND RESULT IN A FIRE.
Remedy:
THE VEHICLE MANUFACTURERS WILL NOTIFY OWNERS OF RECREATIONAL VEHICLES THAT HAD THE REFRIGERATORS INSTALLED AS ORIGINAL EQUIPMENT AND DOMETIC WILL NOTIFY OWNERS OF THE AFTERMARKET REFRIGERATORS. DOMETIC WILL INSTALL A SECONDARY BURNER HOUSING FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN BETWEEN APRIL AND JUNE 2007. OWNERS MAY CONTACT DOMETIC AT 888-446-5157.
Notes:
CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
The following is extracted from the notice provided by Dometic to the NHTSA dated 8/26/06:
The potential defect is associated with cooling unit at the back of the refrigeration cabinet.
A fractional percentage of the potentially affected refrigerators have experienced a fatigue crack that may develop in the boiler tube in the area of the weld between the boiler tube and the heater pocket. A fatigue crack may release a sufficient amount of pressurized coolant solution into an area where an ignition source (gas flame) is present. Dometic's investigation has shown that a simulated release of cooling solution (refrigerant) in the area of the boiler, under certain conditions, could be ignited by the presence of an open flame. A boiler fatigue crack with the loss of cooling solution without ignition would result in a non-operational refrigerator that is not a safety issue. Under certain conditions, the released coolant could ignite and result in a fire. In order to have a fire, at a minimum, all of the following conditions must exist:
    1. The refrigerator must be on and normally operating and gas burner must be lit;
    2. 'There must be an oversized heating element in the refrigerator;
    3. The boiler tube must develop a throughway fatigue crack of a
    specific size;
    4. There must be a release of the cooling solution at a rate which will
    allow the accumulation of the cooling solution at a concentration within its range of flammability; and
    5. There must be ignition source (gas flame) present.
If any of these conditions are not present, a release of the cooling solution will not result in a fire.
In April of 1997 Dometic modified the design of the affected refrigerators by increasing the wattage of the heating element from 325 watts to 354 watts. All production of the affected units from April 1997 through May of 2003 utilized the 354 watt heating element. In May of 2003, in order to improve the operating life of the refrigerators, Dometic returned to the use of the 325 watt heating element which it continues to use today. It is now believed that the use of the higher wattage heater contributed to abnormal fatigue in the boiler tube.
The products in question are all refrigerators used in the original manufacture of recreation vehicles or as replacement equipment for recreation vehicles. The total population of refrigerators potentially containing the defect is 926,877. Dometic estimates a potential maximum incident rate of 0.01% related to boiler fatigue cracks that leak and may result in a fire. There have been no incidents of injury or death related to the affected population of Dometic refrigerators.
Dometic became aware of the occurrence of fires which may have involved their products and retained an independent engineering testing laboratory to fully evaluate and investigate any potential defect in their refrigerators which might result in a fire. A number of returned units were analyzed and microscopic fatigue cracks which could release coolant into the area of the burner were identified in the boiler tube metal in the area of the weld between the heater pocket and boiler tube. Tests simulating the cracks were conducted the week of August 18, 2006 and confirmed a possible cause of fire in the refrigerators under certain conditions. These test results prompted the preparation of this notice.
Dometic continues to gather information on the potential defect and will forward additional relevant information as it becomes available.
Dometic has not yet identified a proposed remedy for the potential defect. Dometic will continue a testing program designed to identify and evaluate possible remedies. This evaluation will take place both in the United States and in Sweden. Once a remedy has been identified, Dometic will initiate or participate in a remedy campaign initiated by the original equipment manufacturers and aftermarket suppliers who have purchased, sold, and distributed these products. A list of original equipment manufacturers and aftermarket suppliers to whom Dometic has sold the potentially defective refrigerators is being prepared and will be provided to the NHTSA upon its
completion.
The following is extracted from the NHTSA response on 9/18/06:
Please provide the following additional information and be reminded of the following requirements:
    Dometic must provide an estimated dealer notification date as well as an owner notification date including the day, month, and year. You are required to submit a draft owner notification letter to this office no less than five days prior to mailing it to the customers. Also, copies of all notices, bulletins, dealer notifications, and other communications that relate to this recall, including a copy of the final owner notification letter and any subsequent owner follow-up notification letter(s), are required to be submitted to this office no later than 5 days after they are originally sent (if they are sent to more than one manufacturer, distributor, dealer, or purchaser/owner).
    Dometic must file a sample of the envelope which you intend to use to mail the recall notice to owners. The words "SAFETY", "RECALL", "NOTICE" in any order must be printed on the envelope in larger font than the customers name and address.
Mel & Mary Ann; Mo'Be (More Behave...) and Bella
"If you have an RV, you don't need another hobby." Comment from a friend...
90 Champion LaSalle MH 29 ft P30 (89 Chassis)
Visit The Official Blog of the Open Road
854 REPLIES 854
GlennH
Chris Bryant wrote:
GlennH wrote:
Got mine fixed today. The folks who did it indicated that due to the positioning of it from the coach manufacturer that they had to pull the fridge to complete the recall. The fridge pull was not paid for by Dometic as part of the recall (manufacturer issue due to installation, I guess...).
Anyone else have this happen and have any luck talking Dometic into covering that. In my case it was $242.50
They should have called Dometic- who will reimburse them for unusual installs (though $242.50 sounds outrageous to R&R a refrigerator).
So far I've done about 10, and the most I had to do was remove the burner on one- though there is one part of the recall which is a pain (reinstalling the burner shield).
30 minutes has pretty much been tops for me- maybe a few minutes more to finish filling out the reimbursement card.
I really could not care less about seeing the paperwork from Dometic- as long as the model and serial number match, I do the recall- even if the owner has nothing from Dometic (a couple have been from me seeing the refrigerator, and the owners knew nothing about the recall).
I called Dometic this morning and asked them and they told me that they would cover it.
Called my shop back and he said that things must have changed, because the paperwork he has doesn't make any sort of accommodations for anything other than the base repair, which he indicated he gets $40 for. He was going to call Dometic and follow up with them. I feel reasonably good about this shop that I had the work done, so I'm sure I'll get my money back one way or the other.
I'll post an update if I find out otherwise.
stevenal
Nomad II
Nomad II
Any of the service people here have extra wiring diagram stickers? The service center I went to put the wrong one on, and when I complained they gave me a photo copy of the correct one. Thought it could easily be solved with a call to Dometic. Guess I thought wrong; they said to go back to the service center. It is impossible for them to remove a sticker from the kit and put it in the mail to me. Looking for the non-universal board diagram. Thanks.
Update: After one rep hung up on me, and others repeatedly told me they couldn't do it, Eric returned my call saying they would pull a diagram sticker from a kit. Watching the mail.
Update 2: Sticker arrived.
'18 Bigfoot 1500 Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
royl
You are forgeting this is an official safety recall which by law must be done free of charge, no matter how the refrigerator is installed. Go back to the dealer and threaton a lawsuit and see how quick you get your money back. If they act dumb on the issue then email Dometic and threaton the same and see if they don't call you back in a day or two to resolve it.
Roy & Sabine
2000 Coachman Classic 27 RK Fifthwheel
1992 Dodge D250
timsrv
Good luck with that. I have called Dometic trying to get more $$$ for reasonable over runs (usually due to installation issues created by coach manufacturer). Not once have they ever reimbursed me. I never felt right charging customer, so I always had to eat it. Just one of the reasons I won't work for Dometic anymore (when it's optional). I'll still handle warranty work on units I've sold, but won't touch anything else. Tim
Chris_Bryant
-- Chris Bryant
DavidC
Is paperwork from Dometic required for the rv service center to perform the "patch"? I just called my guy, and he said, just bring it by and we'll work it in--no appointment. Sounds like an all-day-er to me.
Community Alumni
Not applicable
GlennH wrote:
... due to the positioning of it from the coach manufacturer that they had to pull the fridge to complete the recall. The fridge pull was not paid for by Dometic as part of the recall (manufacturer issue due to installation, I guess...).
No, mine was relatively easy; the rv tech took about 30 minues. After watching him, I could have done it myself without busting any knuckles. :E
GlennH
Community Alumni
Not applicable
osbornk wrote:
I had my kit installed last week and it works fine on both gas and electric.
Same here.
osbornk
I had my kit installed last week and it works fine on both gas and electric. The refrigerator stays in the mid 30s and the freezer is really cold. I used mine both on electric and gas before I took it in to make sure it worked properly before they worked on it.
04 Ford F150 XLT 4X4,5.4L with 3.73 & regular cab
04 Flagstaff 25D
Equalizer-Prodigy
edge540
Had my kit installed two days ago. Now doesn,t work. Yes it worked fine on gas or 115 vac. prior to retrofit. I removed fount cover of the kit 5x8 sheetmetal now it works. Guess it restricts draft up the flew. If you haven,t checked yours on gas, may be you should.
cvrvr
I guess the repair kit is better than nothing. However there is only one way to prevent the refer from catching on fire, buy a new refrigerator.
In the mean time, check your refer very often for signs of yellow dye.
George
George & Karen W
2004 Allegro 30DA
2000 Jimmy toad
FMCA F334632
Chris_Bryant
A piece of information- FWIW, the manual reset limit switch in the recall is an L130C switch- 130ยฐ centigrade would be 266ยฐ F.
-- Chris Bryant
Community Alumni
Not applicable
I had my fridge kit installed today at the same place that Claude B had his done (Belco). It took the Tech 30 minutes and no problems.
Although it doesn't 'fix the problem', at least there is some comfort in knowing the chance of a fire should be gone.
... Eric
Dusty_R
I don't know what your loads are but I would think that you could tie into the 12 volt line that feeds the refrigerator. And yes there are small disk type thermostats, fixed and adjustable setting.
Dusty R
