Dual dump valve with Y / individual blade valve replacement?
ChgoWinger
What is typically easier? replacing the entire waste assemby
(both blades and y in single assembly) like the pic or each of the 2 waste valves with the 4 bolts independantly?
older RV 93 P30 Flair
Thank you
"D"
5 REPLIES 5
SoundGuy
FAR easier to replace just the waste gates ... after all, that's why replacements are so readily available.
3" Waste Gate Replacement Kit
1.5" Waste Gate Replacement Kit
2012 Silverado 1500 Crew Cab
Old-Biscuit
Assembly is slip fit/GLUED to drain pipe so you would have to CUT pipe into, shorten the pipe so you could use a coupling on each side with short piece of pipe to GLUE new assembly in place
Replace the valves via bolts in flanges.
I would unbolt the pipe side of flanges on each dump valve and remove as a WHOLE (valves and drain outlet still bolted together)
Then remove other bolts/valves...install new valves onto drain outlet and install as a UNIT--then bolt it up to drain pipes on each side
ChgoWinger
dons2346 wrote:
Aren't the two openings glued to other pipes? If so, it is easier to do one valve at a time
I wasn't sure. It looks like they could be.
Thanks
dons2346
Joe417
I don't think it would matter as long as you make sure you keep your O rings in place when you slide the valves in.
I've never done both at the same time.
I think I'd go for one valve at a time.
Joe and Evelyn
