โFeb-07-2018 07:32 AM
โFeb-08-2018 02:27 PM
sneakygroundbuzzard wrote:
i spent 17 years as a ford tech(two master certs from ford)
i never did all that to change plugs on one of those vans(and i beat flat rate all the time when i was a tech),but if it works for you,it works for you...
โFeb-07-2018 07:13 PM
DO NOT use any anti sieze or the like on your plug threads or the WILL come loose in time and you will blow the plug right out of the head
jm2c on it
but what do i know ๐
โFeb-07-2018 04:31 PM
โFeb-07-2018 04:10 PM
Gdetrailer wrote:tarnold wrote:
Op here, really great pics! This is a good series on what we have to go thru. Nothing like a F series, which I also have. Looks like the electrodes were about gone on those plug pictures, how many miles were on them? Your sig looks like this might be an 03? My fuel rails look a little different, but basically the same.
Still looking for the flat hour rate discrepancy.
The difference in time may be due to what all NEEDS to be removed and then put back on when done.
There are a lot of changes which happened to the Ford modular series engines as the yrs progressed.
I can tell you from my perspective of F250 trucks, I have had a 97 light duty with 5.4, 2003 F250 with 5.4, 2006 F250 with 5.4.
The 97 was terrible to get to any of the plugs, had to remove fuel rails along with all the duct work for the air to get to the back plugs. Gave up on the rear plugs until I had a COP die, had the shop find and replace the bad COP plus finish changing the plugs.
2003 was a bit easier, did not have to remove fuel rails and was able to get around the duct work for the air intake.
2006 was able to get to all plugs as long as I removed all the air intake duct duct work on top of the throttle body. Did have to remove the screws holding the coolant over flow tank to get to the drivers side back plug.
THE MOST IMPORTANT THING THAT NEEDS DONE, IS TO USE A TORQUE WRENCH TO SET THE PLUGS!!!
FAILURE TO USE A TORQUE WRENCH WILL RESULT IN YOUR ENGINE POPPING PLUGS!
You CANNOT DEPEND ON TIGHTENING BY FEEL.
Make darn sure the mechanic you take it to UNDERSTANDS THIS AND WILL USE A TORQUE WRENCH.
To much and you strip the threads and to little the plugs WILL WORK LOOSE.
You will need to check with your local Ford garage to get the proper torque for your engine year. They do vary a bit between years.
โFeb-07-2018 01:40 PM
โFeb-07-2018 01:10 PM
โFeb-07-2018 11:22 AM
โFeb-07-2018 09:29 AM
campinginthewoods wrote:
I have a 2004 F250 CC pickup 6.8 V10 and my local Ford dealer changed them for $310.00 and it was done in 2 hours. My mechanic wouldn't touch the plugs do to the aluminium heads.
โFeb-07-2018 08:50 AM
โFeb-07-2018 08:22 AM
