Life expectancy of RV Air Conditioners
Gr8life
I am thinking of spending summers in South Texas where the AC will be running almost constantly for three or four months. I wonder how long one will last? Mine is an almost brand new Coleman 13,500 unit.
26 REPLIES 26
DaHose
My 1983 Jamboree has the original Coleman AC unit. That's 32 years and still going after a capacitor replacement.
Jose
TNSnowbirds
I have a 2014 Bighorn with Dometic a/cs and spend the winter in Florida and the A/Cs run almost constantly. The 15K living room unit has been replaced 2 times. The original lasted about 1 year and the replacement lasted about 4 months. The 13.5K bedroom unit is still doing Okay. So I guess your longevity will depend on the manufacture. The Dometics are from China....
2014 Bighorn
2006 GMC 3500 DuraMax
2008 Harley Ultra Classic
Retired USAF CSMgt EOD
"EOD, ain't that a bunch"
dougrainer
AC units are NOT that complicated, whether they be Window/RV/Home units. The BIG difference between an RV and the others is, the RV unit rarely gets maintenance(filters cleaned the evap/condenser cleaned. They are subjected to varying 120 voltages (especially LOW voltages) and that causes excessive wear and tear on compressors and the capacitors. Then when they break, they are called junk. Running 24/7 in a hot climate probably equals 3 to 4 time the normal use in an RV, so you would expect them to wear out/fail quicker. I would expect that the OP's AC unit should last 5 to 8 years in the conditions he will put it in. Doug
Gr8life
j-d wrote:
An RV A/C unit is your basic "window A/C" used for years before "central air." Just rearranged for rooftop operation. Window units last a long time and so do RV units. As long as the campsite provides steady good voltage and amperage, and you keep the coils clean, you'll be OK...Really!
One caution - If your South Texas site is on a beach, salt spray will rust/corrode everything. Your coach, your toad, your lawn chairs, your A/C, you name it.
Thanks. I wondered if they would have similar service lives to window units.
mpierce
The Texan wrote:
My question to all who answered the OP's question and swear the AC will last a lifetime is ...... Have you read where and how he plans to use his AC??? Read the original question, then post an answer based on his criteria.
The Bluebird spent those years in TX, FL and GA, so it spent its life in the south. I do not know what percent of its time being used was in the summer, but I bet it got a lot of AC use in south TX and GA, and FL! I just got it a year ago. The one that failed, it was the board that failed, the AC itself worked by hot wiring it, and controlling with a switch! The board was obsolete, so replaced the whole thing. The other two OEM AC's are going good, knock on wood!
I do not know the history on the Airstream, as to how much the AC was used.
Dog_Folks
My question is: Did you read my post above?
I DID answer his question that about an A/C that is in nearly continuous use.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
mikensallyt
I've got these flimsy sponge like filters and know they don't really block out the dirt. I'm thinking there has to be a better filter. Any suggestions? tks
Retired USN 1996, RMCS(SW/AW)
Traveling solo in my 2015 Thor Challenger since my wife of 25 years went solo to the Lord
Seems like every trip out there's a warranty repair on it afterwards
F/T in two years from now. Last child to graduate first.
j-d
Teacher_s_Pet
Our Phaeton's two Duo-therm heat pumps are working on 10 years of full time use for heating and cooling. The front unit has been replaced twice, with additional control boards and service. The rear heat pump has had one capacitor replaced and we've cleaned the compressor coils 2-3 times. We keep the front at about 75ยฐ during the day, 71ยฐ at night, the rear unit at 80ยฐ days, 73ยฐ at night.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
TechWriter
mpierce wrote:
On our 1964 Airstream, lasted 45 years!
I'm happy for you and I'm sure someone will come up with a 50-year-old AC, but I'm going with a 10-year limit as a rule of thumb.
B4 starting to full time, I replaced both 10-year-old ACs on my Newmar even though just one of them was sounding funky because ACs never fail in Winter.
2004 - 2010 Part Timer (35โ€™ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41โ€™ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31โ€™ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
sdianel_-acct_c
One of our Dometic died after 11 years, the other is still going (knock on wood) and we live in Florida where we run the AC all year and we travel to LA and OK in the summer heat!
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
The_Texan
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
mpierce
Now, on our 1990 Bluebird, just replaced one of three. 25 years, and 2 of 3 still going.
nineoaks2004
I have one on my 1990 pop up that is original, main thing is cleaning the coils and the filters, plus correct voltage.
By the time you learn the rules of life
You're to old to play the game
