โSep-06-2017 12:14 PM
โNov-22-2017 06:52 AM
โNov-21-2017 07:33 PM
โNov-21-2017 05:59 PM
โNov-21-2017 05:26 PM
โSep-06-2017 06:25 PM
mike-s wrote:Jim_Arndt wrote:The fridge won't draw more than 5 A normally, so that's the fuse size. It might try to pull, say, 4 A, but instead of powering the fridge, the power goes into the resistance of the bad connection, which heats up. 4 A @ 12 V is 48 watts, and confined to a small area that equals lots of heat. It's not quite that simple, but the concept is close enough.
Wow, ok, so the fuse would not blow? There is a 5 amp fuse on the powerboard, and a circuit breaker at the main ac panel.
Any time smoke comes from the area of a connection, suspect a bad connection. It may not have been the screw terminal, it could also be a crimped connection. Kinda hard to tell from the photo, not enough resolution.
โSep-06-2017 06:07 PM
ScottG wrote:
First make sure the connection is sound and working.
Then, if you must, apply dielectric grease.
Just keep in mind that DG DOES NOT improve an existing connection.
โSep-06-2017 05:41 PM
โSep-06-2017 05:02 PM
โSep-06-2017 03:32 PM
โSep-06-2017 02:35 PM
โSep-06-2017 02:25 PM
โSep-06-2017 01:57 PM
Jim_Arndt wrote:Old-Biscuit wrote:
Well
Electrical fire at AC terminals on circuit board was probably due to loose/corroded connections.
Water environment requires higher degree of maintenance.
So, are you saying there was resistance at the powerboard AC connector, causing it to heat eventually igniting the wire insulation or other?
I guess I thought a fuse would blow, but I guess not in the above scenario as the current never exceeded the fuse rating.
Scary, as this would apply to a residential fridge or any appliance on board.
So how do you maintain this, after the applicance has been powered on for a while feel the wire for warmth? Learned something new today, thanks guys...
โSep-06-2017 01:43 PM
Well
โSep-06-2017 01:27 PM
