โJun-28-2014 01:45 PM
โJun-30-2014 08:34 AM
jauguston wrote:
To expand on Brians post the propane outside connection is regulated to about 1/2 psi pressure like everything inside a RV. Any propane device that is intended to use the little green one pound tanks will not work on that low pressure. Those devices have a built in regulator. Some with the proper skills have removed the built-in regulator on some stoves to make them work on the low pressure line but care must be taken.
โJun-30-2014 07:54 AM
โJun-30-2014 07:41 AM
โJun-29-2014 05:26 PM
โJun-29-2014 04:59 PM
โJun-29-2014 04:39 PM
red31 wrote:
via their RV connection hose, the $34 stove mentioned above can not, nor can coleman propane stoves (pressure-regulated at 15 psi (pounds per square inch).
โJun-29-2014 09:25 AM
โJun-29-2014 08:56 AM
โJun-29-2014 08:37 AM
โJun-29-2014 06:32 AM
โJun-29-2014 06:23 AM
โJun-29-2014 06:01 AM
โJun-28-2014 10:59 PM
โJun-28-2014 09:31 PM
