Solar combiner box.
Muddydogs
Anyone have some pics or links to a DIY solar panel roof mounted combiner box?
My solar is acting up and not charging, I think its the quick connects coming off the panels to the main line on the roof. Figure I need to remove the quick connects and either solder the connections or run them into a combiner box. Since I need to mess with the stuff on the roof I might as well add another panel for a total of 3 at 300 watts so 3 lines coming into the main line is probably to much to solder together plus if I need to replace a panel having all 3 connected together would be a pain so I might as well just add a combiner box on the roof.
2015 Eclipse Iconic Toy Hauler made by Eclipse Manufacturing which is a pile of junk. If you want to know more just ask and I'll tell you about cracked frames, loose tin, walls falling off, bad holding tanks and very poor customer service.
21 REPLIES 21
hedge
Instead of using cable glands, I made my box to accept mc4 connections so the connections themselves became the passthrough to the box and then the panels plug into the box.
2017 F350 Platinum DRW
2013 Adventurer 89RB
grizzzman
grizzzman wrote:
Colo Native wrote:
Made my own
Home Depot? I have 4 panels parreled to that same box
I have 4 more glands due to running two #6 pos and neg.
This allowed me to run them down the awning mount.
2019 Ford F150 EcoBoost SuperCrew
2016 Rockwood Mini Lite 2504S. TM2030 SC2030
640 Watts Solar. Costco CG2 208 AH and Lifepo4 3P4S 150 AH Hybrid. ElectroDacus. Renolagy DC to DC charger. 2000 Watt Inverter.
Boondocking is my Deal
grizzzman
Colo Native wrote:
Made my own
Oops double post
Optimistic_Para
Muddydogs wrote:
Thanks for the pic. I'm going this route as well, I have some thick copper and aluminum I can cut down and tap for a couple buss bars. Can't find any waterproof box inlets for the smaller solar cable but I figure I'll get a couple bigger waterproof inlets and just fill the extra space with some caulk once I get it together.
These come in various sizes:
Cable Glands
Muddydogs
Colo Native wrote:
Made my own
big_buford
Just cut 2 mc4 connectors out of a buddys system not charging. I would assume all MC4's are not created equal?
04.5 GMC 2500HD D/A
06 38 CKS Dune Chaser
Chenowth 4-seat 3.5 honda
15 maverick xds
Beautiful wife that's much nicer than me:B
Colo_Native
Made my own
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
mike-uswest
I have used two of the AM Solar boxes, and they are quick and efficient.
Mike
2019 Ram 2500 TCD, 4X4,
Arctic Fox 25Y 30'
pauldub
I used one of these.
AM Solar also offers a combiner box that suitable for RVs.
Muddydogs
Spridle wrote:
In your case, a combiner box is nothing more than a water tight box with terminal strips inside. You will have to secure the box to the roof. Assuming you have two panels you will need 6 entry glands to keep the cable entry points water tight. A quality box is expensive.
Combiner Box Hyperlink
You could replace your MC-4 connectors because yours are either damaged, cracked or never tightened and water got inside. MC-4 connectors dont leak if they are not damaged and installed correctly. They are used on every commercial solar installation I have seen. Also tiewrap the connectors so they are not setting on the roof in a puddle of water or snow.
Crimp Tool Hyperlink
and the connectors, get the correct size for your wire gauge.
MC-4 Connectors hyperlink
You should replace your two "Y" combiners, water probably got inside.
I would say the problem is the connectors have set for 3 years in water or snow all winter long as my trailer is stored outside, some years I have a couple feet on the roof almost to the point where I start thinking about removing some. I'm sure the Wyoming wind hasn't helped when towing either.
I'm sure everything was tight when I installed it but who knows now? I haven't checked the connectors myself as it was all we could do to get the smallest guy in hunting camp on the roof when I noticed the problem. Once home I pulled the battery's and put the trailer up for the winter figuring I would deal with it in the spring. I'm just trying to get a plan now, pick up supplies and decide if I want to add one or two more panels to the system.
Spridle
2oldman
Muddydogs wrote:
After a quick refresher reading I want to stick with parallel as most of the time I'm in shady areas.
I try to find non-shady areas.
Muddydogs
Optimistic Paranoid wrote:
Muddydogs wrote:
Thats what I have now on the roof. When you wiggle the connectors I get 14.4 volts when not wiggling them I get 12.3 which is what the battery's are charged to.
I suspect that if you unhooked them and gave them a thorough cleaning with DeOxit, your problems would go away.
DeOxit
I was first turned on to this stuff by an electrical guru I knew. It's worked wonderfully well every time I've used it.
BTW, you know you need a special (inexpensive) tool to disassemble MC4 connectors, right?
I'm sure I could clean them but there's always the next time they don't work and my trailer roof is a long ways up with no ladder to access it. I would much rather take the connectors out of the equation and do it right. Plus adding a third panel will complicate the connectors needed.
A tool would be nice I'm sure but I just did it with my fingers, didn't know I wasn't supposed to be able to without the tool.
Optimistic_Para
DeOxit
