Oct-16-2018 08:27 AM
Oct-17-2018 06:53 PM
Oct-17-2018 12:03 PM
grizzzman wrote:Colo Native wrote:
Made my own
Home Depot? I have 4 panels parreled to that same box
I have 4 more glands due to running two #6 pos and neg.
This allowed me to run them down the awning mount.
Oct-17-2018 12:02 PM
Colo Native wrote:
Made my own
Oct-17-2018 11:48 AM
Muddydogs wrote:
Thanks for the pic. I'm going this route as well, I have some thick copper and aluminum I can cut down and tap for a couple buss bars. Can't find any waterproof box inlets for the smaller solar cable but I figure I'll get a couple bigger waterproof inlets and just fill the extra space with some caulk once I get it together.
Oct-17-2018 10:47 AM
Colo Native wrote:
Made my own
Oct-17-2018 09:43 AM
Oct-16-2018 05:31 PM
Oct-16-2018 03:56 PM
Oct-16-2018 02:02 PM
Oct-16-2018 12:18 PM
Spridle wrote:
In your case, a combiner box is nothing more than a water tight box with terminal strips inside. You will have to secure the box to the roof. Assuming you have two panels you will need 6 entry glands to keep the cable entry points water tight. A quality box is expensive.
Combiner Box Hyperlink
You could replace your MC-4 connectors because yours are either damaged, cracked or never tightened and water got inside. MC-4 connectors dont leak if they are not damaged and installed correctly. They are used on every commercial solar installation I have seen. Also tiewrap the connectors so they are not setting on the roof in a puddle of water or snow.
Crimp Tool Hyperlink
and the connectors, get the correct size for your wire gauge.
MC-4 Connectors hyperlink
You should replace your two "Y" combiners, water probably got inside.
Oct-16-2018 11:59 AM
Oct-16-2018 10:48 AM
Muddydogs wrote:I try to find non-shady areas.
After a quick refresher reading I want to stick with parallel as most of the time I'm in shady areas.
Oct-16-2018 10:31 AM
Optimistic Paranoid wrote:Muddydogs wrote:
Thats what I have now on the roof. When you wiggle the connectors I get 14.4 volts when not wiggling them I get 12.3 which is what the battery's are charged to.
I suspect that if you unhooked them and gave them a thorough cleaning with DeOxit, your problems would go away.
DeOxit
I was first turned on to this stuff by an electrical guru I knew. It's worked wonderfully well every time I've used it.
BTW, you know you need a special (inexpensive) tool to disassemble MC4 connectors, right?
Oct-16-2018 10:18 AM
