โMay-27-2010 02:06 AM
โSep-04-2010 07:43 PM
canadiankid wrote:
Can anyone else comment on a 2000 Honda or Yamaha and a microwave please.Thanks.
โSep-04-2010 06:20 PM
โSep-04-2010 05:56 PM
โSep-04-2010 05:29 PM
Wayne Dohnal wrote:
IMO the inverter generator is getting more power from the same displacement engine by spinning it faster. The eu2000i, for example, runs at a top engine speed of 5,000 rpm instead of being constrained to 3,600.
โSep-04-2010 02:23 PM
Engine/Electronics efficiency.IMO the inverter generator is getting more power from the same displacement engine by spinning it faster. The eu2000i, for example, runs at a top engine speed of 5,000 rpm instead of being constrained to 3,600. The eu3000i by comparison uses a engine with twice the displacement for 50% more power, but its run speed tops out at 3,500 rpm. I don't see that CPE or Yamaha publish the engine speed for their inverter generators. When I crunched fuel consumption vs. power output numbers I concluded that when running at full power output, the inverter generators have a very small efficiency advantage, but it's so small that I'd just call it even. My guess if that the inverter generator's alternator is more efficient, but that gain is lost in the rectifier/inverter circuitry. I assume it's pretty well known by now that at less than full power the inverter generator just stomps the conventional generator, efficiency-wise. Part of that would be due to being able to use a smaller displacement engine, and part due to spinning a lower mass and/or spinning it at a lower speed.
Take for example the Champion 80cc engine. With the common AC alternator their model 40048 is listed as 1500w/1200w and their model 73531i is listed as 2000w/1600w ~ The question is, through the process of first DC then AC and the power module (Inverter) one can increase the efficiency of a given displacement???:? Or is this, playing with the numbers? Both models are direct drive so no way to say the difference is in the transmission.
โSep-04-2010 11:22 AM
byates wrote:
I think the answer lies in the quality of the breaker switch, not whether it is thermal push button, thermal/magnetic switch, or solid state switch.
โSep-03-2010 07:18 PM
โSep-03-2010 02:47 PM
โSep-03-2010 10:36 AM
โSep-02-2010 01:56 PM
โSep-02-2010 09:05 AM
โSep-01-2010 06:39 PM
โSep-01-2010 03:48 PM
โAug-31-2010 04:13 AM
SurfaceDreamer wrote:Old & Slow wrote:
S.Dreamer,
You seem willing to share all your knowledge of Champion and Sam's Club. This Inverter has been on the market for about a month now with no 'It's a marvel reports' Maybe you can pass along some knowledge as to real facts. What is the output in watts after 30 minutes. Maybe 1200w? Will two of them together operate a 13,500 btu A/C for more than 30 minutes on a Arizona 100 degree day? Howabout the noise. At full bore of 80cc @ 4000 plus rpm, is it as quiet as the Honda EU2000i? Do we have real competition with this New Champion Inverter to H & Y. If so, we will add to the CCC's less than quiet chant. I already belong.
BTW: Please don't leave us like several other posters after droping in and out with only two or three posts. Some came and went with less.:h
I'll share what I can when I get the first chance to test things. Between work, school and family my time is at a premium and I probably won't have time to really look at things for at least a few more weeks.
My family and I are on a lot of firsts here; our first trailer, our first generator and our first camping trip in 2-3 weeks (the plan as it stands today). As for the CPE 2000 unit - I know I took somewhat of a leap of faith based on overall CPE views on many boards. Considering the price of other units I was looking at (Kipor, Boliy and Yamaha) I'm hoping it works out. I will keep you posted on what I find.
P.S Without digging around and having not looked at the documentation for the unit - what is the easiest way most people determine power output for a generator? I have no experience with any other generator so I'm not sure I'll be able to help with the noise comparison except of my interpretation of how it sounds. I'll do my best though ๐
โAug-30-2010 09:42 PM
