โMay-27-2010 02:06 AM
โMar-02-2013 09:44 PM
โMar-02-2013 07:10 PM
โFeb-22-2013 02:04 PM
โFeb-22-2013 01:15 PM
โFeb-22-2013 12:53 PM
โFeb-22-2013 12:27 PM
โFeb-22-2013 11:40 AM
โFeb-22-2013 10:29 AM
โFeb-18-2013 06:54 AM
Night_Wolf wrote:
Anyone running the Dometic LW3000 Plus Digital Inverter? It's a 3000 watt unit (not sure if that is peak or continuous)and I picked it up for $800.00 plus taxes at the recent RV Dealer show in Calgary Alberta. Brochure claims it make 59db at 4m or 13' That is at idle from what I can tell. It comes with a battery and a keyed ignition,but the battery doesn't seem to want to hold a charge :R No matter, turn the key to on choke it, pump the fuel bulb about 6 times and a cpl pulls on the cord and it fires up. Had to purchase a twist lock adapter to hook it to the toy hauler. Unit comes with a few basic accessories but no oil & it uses 15w40 (just under a litre/quart)
Since I had a Hyundai 1000 watt unit (1250 peak) I decided to perform a side by side comparison using a 1500 watt ceramic type space heater. It was filmed using a Canon Power Shot A530 mounted on a tripod
Here's a Dometic Dometic LW3000 Plus Link to the comparison that I uploaded to U-Tube
โFeb-17-2013 09:25 PM
โFeb-15-2013 05:55 PM
โFeb-15-2013 05:10 PM
โFeb-15-2013 04:39 PM
Glenlivet wrote:
I can run my 5500 BTU air conditioner AND my 1000 watt microwave oven simultaneously, with my Champion 2000 watt inverter! Caveats: The generator must be fully warmed up, the air conditioner must have cycled on first and then power up the microwave, and understand that the generator will be running in its highest RPM step if its in Economy mode, but yes the little thing will handle it.
I'll take a video if necessary for unbelievers, but it will have to be later after it warms up some around these parts, for the A/C compressor to cycle on.
โFeb-15-2013 04:14 PM
โFeb-15-2013 03:18 PM
