โDec-27-2021 08:37 AM
โDec-27-2021 06:05 PM
3 tons wrote:s/b able to wire it either way and still have low voltage stop the heating to protect the battery. Otherwise need to keep warm to keep the solar controller active. If low voltage turns everything off it waits in storage mode for a power source.SDcampowneroperator wrote:LittleBill wrote:Wont the heating option then use battery power?
this has been solved. they now sell bms's with heating options. When I make the switch they will be used in 0f unprotected temps.
No, the heating option is powered by the batteryโs charging source.
3 tons
โDec-27-2021 05:11 PM
โDec-27-2021 04:51 PM
โDec-27-2021 04:29 PM
โDec-27-2021 04:15 PM
time2roll wrote:
I don't think I could survive at that temperature unless I had continuous utility power to heat both the battery and propane cylinders. In which case LFP would be fine.
If power went out, I think I could still make the night to roll out in the morning.
I can't imagine SiO2 retains all its rated energy at that level either.
When do we get a trip report? ๐
โDec-27-2021 04:12 PM
โDec-27-2021 04:09 PM
โDec-27-2021 04:08 PM
โDec-27-2021 04:02 PM
โDec-27-2021 02:25 PM
โDec-27-2021 02:17 PM
โDec-27-2021 01:40 PM
โDec-27-2021 01:04 PM
โDec-27-2021 12:36 PM
