โNov-20-2017 04:59 PM
โNov-25-2017 03:41 PM
โNov-22-2017 08:48 AM
coolmom42 wrote:
Your air admittance valves in the drain lines have failed. There is one under both the kitchen and bathroom sinks somewhere. They are supposed to allow air to move in one direction-- into the drain lines when you dump the tanks, to avoid sucking the P-traps dry. But they are letting stinky gas from the gray tank in, when the gray tank space is being filled by your shower water.
When you open the tank drain, that lets the displaced air go on down the drain. Right now it's burping back up through the air admittance valves.
Air admittance valve
It's also likely your tank vent is plugged--either with bird or insect nest. The tank vent could also have slipped down (at the factory) and be sitting right on the bottom of the tank.
โNov-22-2017 08:16 AM
โNov-21-2017 07:04 AM
โNov-20-2017 07:57 PM
โNov-20-2017 06:00 PM
byronlj wrote:
Close your gray tank valve let it mostly fill and then add some bleach by pouring down the sink or shower. Let it sit for several hours and then drain. Even the gray tank gets stinky.
Dave
โNov-20-2017 05:55 PM
โNov-20-2017 05:44 PM
โNov-20-2017 05:35 PM
โNov-20-2017 05:09 PM
โNov-20-2017 05:08 PM
tinstartrvlr wrote:
Evening everyone,
I seem to have an issue with the gray tank venting properly, and it only occurs while taking a shower.
There is a rotten stench that comes from a ceiling level kitchen cabinet, with a lesser smell coming from under the kitchen sink and from the bathroom vanity.
Roof vent is clear, the under sink vents seem okay; by that I mean I took them off and the diaphragms seems to be moving freely. I don't know how to tell if they are faulty however.
Don't believe the water heater is the source because I never have the smell unless showering, (hot water doesn't smell otherwise) and I use the shower daily. Diligent about flushing the water heater regularly.
No dry P traps, no break in the vent pipe that I can find; I have tried all the usual suggestions I have read here previously, but I certainly could have missed something.
So it was suggested to me by a neighbor that I leave the gray tank drain valve open, and voila, no smell.
Anyone know why leaving the gray valve open would eliminate the smell?
โNov-20-2017 05:05 PM
