Water Pressure Regulator - Two Questions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Dec-30-2013 07:21 AM
Next question...for those of you who can adjust your water pressure...how high do you set it? My owners manual says not to exceed 45 psi or the warranty is void. Warranty is out of date and manufacturer is out of business so that doesn't matter anymore. Question is what is a practical safe upper limit?
2005 Silverado SB, 2500HD Crew Cab, D/A, 42 gal aux tank, Garmin 1490T, XM Sat Radio,
2005 Alpenlite Valhalla, 16K Reese Manual Sliding Hitch,
Tonka the Rat Terrier guards the rig.
Lucky the Chihuahua guards Tonka.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jan-01-2014 05:00 AM
Hoosier Cruiser wrote:
Filters will reduce flow, but pressure will be the same.
That is correct. When the flow stops, the pressure will be the same on the output side of the filter.
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 06:21 PM
Pirate wrote:
Take them (pressure gauge) (even oil filled) inside when freezing out.
Took me 3 gauges to figure this one out.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 05:47 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 03:28 PM
Terryallan wrote:
Straight up, and down should be possible with a 90 degree elbow attached to the city water connector on the RV. They are readily available at Wal Mart, or your local RV dealer.
Then the water hose and any filters in-line are not protected from high pressure with regulator at RV.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 03:01 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 01:57 PM
hohiso wrote:Old-Biscuit wrote:skipnchar wrote:OP wrote:
Finally bought a 'real' pressure regulator that has a gage and is adjustable.
Hard to imagine why anyone would want to reduce pressure to less than maximum their RV is designed to handle. INCREASING pressure above that level when source is low pressure won't increase water pressure at all so not sure what the adjustment would do for you.
Mainly because the 'fixed' pressure regulator are set at 45#
With an adjustable one you can choose what pressure set point you want to use......30, 45, 50, 55, 60..whatever you are comfortable with.
And with an adjustable regulator......chances are it is re-buildable if needed
Also, I have been told by someone who knows that the typical cheap in-line regulator restricts flow as well as reducing pressure.
I personally have always called the cheapies a water reducer,never a regulator..jb
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2011 Crossroads Cruiser cf32mk Patriot edit. 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 01:29 PM
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 01:26 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 12:30 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 12:21 PM
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 10:01 AM
30, 45 and 90 degree, Given one of each you can dang near turn === to ||
Any lawn and garden shop.,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 09:35 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 08:58 AM
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dec-30-2013 08:33 AM
Had been thinking about an Oxygenics shower head and your recommendation just tipped the scales in its favor. Thx
