โDec-30-2013 07:21 AM
โJan-01-2014 05:00 AM
Hoosier Cruiser wrote:
Filters will reduce flow, but pressure will be the same.
โDec-30-2013 06:21 PM
Pirate wrote:
Take them (pressure gauge) (even oil filled) inside when freezing out.
โDec-30-2013 05:47 PM
โDec-30-2013 03:28 PM
Terryallan wrote:
Straight up, and down should be possible with a 90 degree elbow attached to the city water connector on the RV. They are readily available at Wal Mart, or your local RV dealer.
โDec-30-2013 03:01 PM
โDec-30-2013 01:57 PM
hohiso wrote:Old-Biscuit wrote:skipnchar wrote:OP wrote:
Finally bought a 'real' pressure regulator that has a gage and is adjustable.
Hard to imagine why anyone would want to reduce pressure to less than maximum their RV is designed to handle. INCREASING pressure above that level when source is low pressure won't increase water pressure at all so not sure what the adjustment would do for you.
Mainly because the 'fixed' pressure regulator are set at 45#
With an adjustable one you can choose what pressure set point you want to use......30, 45, 50, 55, 60..whatever you are comfortable with.
And with an adjustable regulator......chances are it is re-buildable if needed
Also, I have been told by someone who knows that the typical cheap in-line regulator restricts flow as well as reducing pressure.
โDec-30-2013 01:29 PM
โDec-30-2013 01:26 PM
โDec-30-2013 12:30 PM
โDec-30-2013 12:21 PM
โDec-30-2013 10:01 AM
โDec-30-2013 09:35 AM
โDec-30-2013 08:58 AM
โDec-30-2013 08:33 AM
