โJan-20-2018 08:26 AM
โJan-20-2018 02:37 PM
GordonThree wrote:
If you're just building the system and haven't bought anything yet. Go for higher voltage. 8x golf cart batteries (or a lithium pack) gets you a nice 48v system. This lets you use lighter cable, and everything else is much more efficient. An inexpensive DC-DC converter provides 12v for small loads like pump, lights, etc.
โJan-20-2018 02:35 PM
opnspaces wrote:
I am going to install an inverter in my trailer and am curious about what gauge wire I need to run from the batteries. To be honest I really don't have an application or device I want to run off it. I just want to do it for the "because I can" factor. I plan to mount the inverter against the front wall of the trailer so I don't imagine more that ten feet of DC wiring from batteries to inverter. Below is what I have to work with since I already own them.
A Zamp 2000 watt pure sine model ZP-2000ps. What gauge wire would I need to get optimal use from this? (Figure 10 feet from battery to inverter). This is the one I'll probably use as this is what I had in mind when I bought it.
or
a Zamp 600 watt pure sine model ZP-600ps. What gauge wire would I need if I decided to install this model instead. (Figure 10 feet from battery to inverter).
Is voltage drop a concern in this kind of setup, or is that mostly a concern with solar installs?
Thanks
โJan-20-2018 02:27 PM
โJan-20-2018 02:21 PM
โJan-20-2018 01:49 PM
โJan-20-2018 01:42 PM
GordonThree wrote:
10 feet is 5 feet too many for a 2000 watt in my humble opinion. Remember round trip, whatever your wire length is, double it, since you have a positive and negative wire, and the electricity flows through both. Voltage drop is a very real concern especially under heavy load.
For my 2800 watt 4000 watt surge inverter I used 4-ought #0000 welding cable, 12 feet total round trip which includes 6 feet for the cable linking four batteries in parallel.
Keep your DC cables very short and use an extension cord at the output to get AC where you need it.
โJan-20-2018 01:09 PM
โJan-20-2018 01:08 PM
โJan-20-2018 12:52 PM
โJan-20-2018 12:51 PM
opnspaces wrote:
wow, thanks for the education everyone and thanks Soundguy for the chart. It looks like I better figure out realistically how long my run will be so I can if I really want to do this and how much it will cost.
Soundguy said he doesn't pull more than 70A. What would cause that kind of load?
โJan-20-2018 12:39 PM
โJan-20-2018 11:02 AM
โJan-20-2018 10:01 AM
โJan-20-2018 09:54 AM
โJan-20-2018 09:28 AM
opnspaces wrote:Not sure what you mean there...solar wiring is a different subject.
