What did you do to your truck today?
AKSuperDually
I love cruising through the "what did you do to your camper today" thread, I figured I'd add a "what did you do to your truck today".
I'm sure that many of you are like me....and your truck that you use to haul your camper gets a lot of special attention to make sure it's in tip-top shape for your adventures.
I'll start out.....
Today I mounted 2 PIAA 520 Fog lights and 2 PIAA Driving lights to my winch bumper, and aimed them.
This evening, I received a box containing torklift stableload bumpstops. Those will have to wait for another day....we've got a blizzard going on here.
2000 Ford F350 DRW 4x4 7.3L
2003 Arctic Fox 1150
482 REPLIES 482
7_3driver
Weight truck/camper
Truck: 1999 F350,crewcab, dully, 7.3 w/automatic, fuel tank full (36-37 gal.).
Camper: 2000 Bigfoot 25c10.6, 1 battery, no propane tanks, 2500 generator and foam mattress. Other wise empty.
No driver.
10660 lbs.total. Front axle 4140 lbs. Rear axle 6520.
Max 11200 lbs on the door tag.
JoeChiOhki
Thunked the blower motor for the hvac systems with the tire checking stick to get it unstuck again, because I'm a procrastionator on fixing small non-critical stuff when I have big ticket cost repairs coming up very shortly.
My Blog - The Journey of the Redneck Express
CB
Channel 17
Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
Ramblin__Ralph
Got on the road for Ramblin' 2022 (my 17th year)! First stop at an RV Park in Gilroy, CA. This weekend I'll start a one week campout with my 2 kids in the beautiful E Sierra. After that TBD, but to heck with gas prices!!
Safe travels to all,
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Bilstein Shocks, TorkLift Stable Loads, 100 Ah LiFePo4, 225 watt solar
My RV Travels Webpage / Yearly Campsite Map / 740 Campsites / YouTube Videos /
Instagram
Grit_dog
Navigator
Navigator
S Davis wrote:
Installed a 51 Gallon aux tank for a total of 87 gallons.
Nice clean install!
But why all the extra parts and filter? Not down with gravity fill?
Whatโ€™s the top line off the tank for?
JoeChiOhki
Continued my search for the unicorn that is a replacement early 90s Ram Charger Gas tank and scheduled a front end overhaul with my brother for the Juneteenth weekend.
Next up will be new steer tires as the worn out ball joints have caused damage to the existing ones (The tires are all ten years or older, so replacing them was always on the docket).
CB
Channel 17
Redneck Express
notsobigjoe
Nomad III
Nomad III
I would imagine 87 gallons would get you where your headed, then some, and back again. It's a great job.
S_Davis
notsobigjoe
Nomad III
Nomad III
specta wrote:
I'm shocked at now much the spring assisted rear shocks helped stabilize my truck in corners, very surprise and pleased with the front and rear shocks.
Yeah, I hear you. I put a pair of aftermarket short stroke on the front and rear. I have to go aftermarket because of the lowered truck. They are amazing.
jimh406
I guess you don't know what you are missing if you don't do any mods.
specta
Kenny
1996 Jayco 376FB Eagle Series TT
1997 Jayco 246FB Eagle Series TT
1976 Ford F-250 4wd Mercury Marauder 410 - 4V
Regular cabs. The best looking trucks.
specta
notsobigjoe wrote:
Love the shocks
All 4 were just over $200 at rockauto.com
Kenny
notsobigjoe
Nomad III
Nomad III
Love the shocks
specta
I changed the oil and filter, again. LOL And rotated the tires.
I change it every 5000 miles and it usually still has 50% of the oil's life left.
My camper has been on the truck for the last 5000 miles so I'm guessing it shortened the oils life a bit.
I put new shocks on the truck too, 2nd time for shocks.
The first time I changed them was at 171,000 miles and I used Monroe Reflex shacks and they really didn't make much of an improvement over the original shocks.
This time I bought AC Delco shocks and spring assisted shocks for the rear.
I am amazed that at 235,000 miles the truck still isn't ready for new brakes.
When they are due they'll get replaced with factory SC Delco brakes.
Looking forward to my trip to Kanab tomorrow to see if the new shocks helped. ๐Ÿ™‚
Kenny
Bedlam
Moderator
Moderator
jimh425 wrote:
Bedlam wrote:
Currently, I have the 225's with 4.44 gearing. My Toyo's are 245's which will make cruising RPM a little less. 65 mph is 2000 rpm in stock trim.
What width rims are you running?
I have 6" width rims, but 245's will fit them. About 1900 RPM in 6th gear at 65 mph and 2300 RPM in 5th gear. At 17.5k lbs GVW, I did not feel a loss in power. I won't have my trailer in tow until December to know how it feels with an additional 7k lb load.
Buzzcut1
Nomad II
Nomad II
Pulled off the outer dually wheels. Taking them to the shop for new rubber before we take off on a 5000 mile trip in two weeks (already put new tires on the inners)
edit:
4 new tires in place for the trip
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
