โNov-02-2016 07:36 PM
โNov-06-2016 11:31 AM
โNov-05-2016 02:11 PM
โNov-05-2016 01:59 PM
Powerdude wrote:
I don't think it's all its advertised to be, personally. I'm sure people are happy with their 3.5 L put-put squirrel molester, but wait until you hit 100k-120k miles and you have to shell out $2000 bucks for new turbos.
โNov-05-2016 10:33 AM
Powerdude wrote:
If you look at those torque curves, the EcoBoost doesn't have jack for torque at 1000-1500 RPMs, because the turbos haven't spooled up.
At that RPM, it's just a 3.5 L V6. Yeah, it sips gas at that level, but you don't get torque and power until the turbo's kick in air into the engine.
At that point, you have to inject gas, or you'll throw a rod out due to lean condition. When the turbos kick in, you get power and torque, but that kills your gas mileage.
โNov-05-2016 08:53 AM
โNov-05-2016 07:25 AM
โNov-05-2016 05:07 AM
BenK wrote:
Anyone know if this new 10 speed tranny disconnects TC Lock for long during a shift?
That is where most of the heat is generated...unlocked
It almost has to unlock in order to shift and asking in case they have solved that
in some fashion
โNov-04-2016 05:46 PM
wcjeep wrote:
Latest Consumer Reports found big multi speed transmissions problematic. Are you sure you want to be the first on the block with the 10spd?
โNov-04-2016 11:19 AM
โNov-04-2016 10:06 AM
โNov-04-2016 08:29 AM
theoldwizard1 wrote:Grit dog wrote:
And so much for locking it in a gear to keep the trans from hunting fo gears.
I have to believe you can do this ! I can on my 6 speed auto in a 2016 Ford Edge.
โNov-04-2016 06:21 AM
โNov-04-2016 05:19 AM
Customers don't want a "busy" transmission (constantly shifting up and down) but also don't want to have to stomp on the pedal to get it to "kick down).
The shift schedule will be very different in "tow mode".
โNov-04-2016 04:26 AM
ShinerBock wrote:
Actually no. Due to how much low end torque the current Ecoboost has, it hardly spends any time below sixth while cruising unloaded. It would hold gears on hills that would make most N/A V8s drop down a gear or two.
