12 volt TV
Fishhunter
Wanting to add a 12 volt TV w/ built in DVD for an upcoming 2 to 3 month trip. Wondering which brands are better. Wanting something between 15 and 19 inches, TC is pre-wired best I can tell.
2021Ram 3500 DRW
2020 Arctic Fox 29-5K
ORV 24RLS Titanium (Sold)
2015 Adventurer 86FB (Sold)
12 REPLIES 12
djg
I guess im spoiled I have a 32" Haier with a blueray player running off my 400 watt inverter both 110vac have two group 31 agm batteries, use a cpap machine and have never run out of power can run for days on the two batteries but I generally drive during the day so batteries get charged, uses about .4 off the battery per day
2015 Livnlite Camplite TC10
1995 Ford F-350 dually 7.3 Diesel
Rbertalotto
Best Buys Invicta house brand TVs all run on 12V "wall Wart" adapters.
I have a 28 and a 22 in my Toy Hauler. Work great right off the 12V system.
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
Wardster
I went this route - see link
12V TV & BluRay Player
2016 Northern Lite 8'11" Q Classic Special Edition
2003 GMC 2500HD Crew Cab 4x4 - Duramax/Allison
Bedlam
Moderator
Moderator
I also use 110VAC 22" TV+DVD combo with a 300w inverter.
1mtnman
I also use a 300 watt inverter with a power strip. I can charge my cell phone, run my TV and or DVD player all at the same time.
jimh406
I use 110v tv/bluray on an inverter as well.
bobbolotune
I have a Jensen 12V. Here is the 19" model:
Jenson 19" On Amazon
I thought the 19" was a little small so I got (if I recall) the 24" model. It plugs into the round 12V cigarette lighter connector. The TV has worked fine. It is only the TV, it does not include a DVD.
Lance 850 truck camper
2016 Ram 3500 regular cab long bed 4x4 DRW 6.4L HEMI gas
ScottG
I run our color TV through a 12V, 120 watt inverter. Works great, pulls less than 5 amps.
hedge
As above, I have an Insignia from bestbuy and a Sony Blu-ray player. Cut off the plugs and wired them direct to a 12v plug. Been using it this way for three years.
I did have it flake out on me one time when the furnace came on but it only did it once and it only affected the blu-ray player.
2017 F350 Platinum DRW
2013 Adventurer 89RB
qtla9111
darsben1 wrote:
Some small 110 volt TV's are really 12 volts in disguise.
Go into a store or look on AMAZON. If it has a puck in the power cord like a laptop it is most likely 12 volt.
Just get a 12 volt cord with the proper end..
I have 2 like that one from Walmart and one from BestBuy.
3 years in the motorhome with zero problems
Very cool idea. I never would have thought. I've been looking to replace our old digital that uses 60Watts. We use it for local news.
2005 Dodge Durango Hemi
2008 Funfinder 230DS
Living and Boondocking Mexico Blog
northshore
I got an "Element" tv from walmart, I think it was $99.00. It is 12 volt just like explained above. Works fine, mine is probably the bottom of the line, does not have a dvd player internal, and maybe Walmart has one with the dvd player.
darsben1
Traveling with my best friend, my wife in a 1990 Southwind
