Aug-05-2014 12:45 PM
Aug-11-2014 08:54 PM
Aug-11-2014 07:38 AM
rwess wrote:
With your proposed 5th wheel with the extra frontal area that sticks up above the truck, I would not be surprised if you are in the 6 MPG range.
MHWASH wrote:
We had a '09 CC, LB with the 6.0L. It pulled our 24'TT just fine. Then we upgraded to a 31' TH @ 9500 lbs. RPMs were constantly in the 3000-3500 range on any kind of hill. It got an avg. of 6mpg towing. I was concerned with longevity of the motor and tranny running those high RPMs all the time. When the tranny would shift down going down grades it scared the******out of me. I don't ride my brakes, but just trying to slow down a long grade would cause the tranny to shift, similar to the Allison, causing the motor to increase its speed by about 1000 RPM. I got in the habit of shifting in to manual mode going down hill.
Aug-10-2014 08:32 AM
Aug-08-2014 02:05 PM
Aug-07-2014 05:00 PM
coodle0216 wrote:
We have an extended cab, short bed truck. We installed the airbags just to keep the truck level.
Thanks !! 🙂
Aug-07-2014 02:47 PM
Aug-06-2014 05:06 PM
Aug-06-2014 01:49 PM
Thanks !! 🙂
Aug-06-2014 01:29 PM
Aug-06-2014 09:38 AM
Aug-06-2014 09:30 AM
coodle0216 wrote:
Our dry pin weight is 1440. Thank you for all your info and answers!! It has helped alot.
Aug-06-2014 09:16 AM
Aug-06-2014 09:01 AM
Aug-06-2014 08:23 AM
