Mar-30-2014 03:53 PM
Mar-31-2014 03:50 PM
awoodwaring wrote:Terryallan wrote:
Wow. What kind of bunkhouse are you looking at that weighs that much? My 30' Apex is 4811lbs dry. Loaded, Ready to camp it is less than 6000lbs. There is absolutely no excuse for loading that much stuff in to a TT. There isn't anywhere to put all that******any way.
For those of you that think I'm crazy. Yes a scale was involved. The TT was loaded with pots, pans, silverware, cups, blankets, towels, bedding, blankets, 10 folding chairs, 2 folding tables, a grill, awning matt, and campstove, Some food, a dining fly, a huge cooler, Griddle, and some clothes. Along with stove , TV, and cooler stands.
What else could a camper possible need?
Most of the ones I looked at gave an approximate 9600 lb fully loaded weigh, like the Shadow Cruiser I listed above.
Mar-31-2014 03:18 PM
ktosv wrote:ib516 wrote:
However, if you plan cross country trips or those that involve mountain grades, it'll be under powered IMO.
I guess that I need to retire my van from towing considering it has a measly 323HP and 373#-ft of torque compared to the 355HP and 383#-ft of torque of the Silverado. All though don't tell my van that cause it has towed flawlessly to this point.
As others have mentioned, you will be challenged by your payload. In my opinion, you have more than enough power to tow such a trailer.
Mar-31-2014 02:23 PM
The Texan wrote:l001952119 wrote:Not entirely true......Yes, the engineers determine the actual numbers, THEN the bean counting legal department determines the "published" numbers, which are considerably lower than the ones the engineers derived. You think not, go look up the identical truck, sold in a foreign country and look at their published numbers.....It will open your eyes.
Pay attention to the GM published weight ratings. They are determined by engineers, not wayward RV'er's!
Mar-31-2014 02:19 PM
Mar-31-2014 08:08 AM
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
Mar-31-2014 07:49 AM
any trailer fully loaded at 9800 lbs??
Mar-31-2014 07:32 AM
Mar-31-2014 07:22 AM
awoodwaring wrote:Add the 6.2 gas engine with 420 horse and 460 torque with the Max trailer package and you have 12,000 GTW. I have this in my 2014 Silverado crew cab. The gas mileage has not been determined in "real life scenarios", but it will cost you for the "premium" grade gas required by GM. The hitch is rated for 1000 tongue weight and 12000 towing capacity. The 3/4 ton can tow 13000 with a 4.10 rear end. That will surely eat up the gas! Pay attention to the GM published weight ratings. They are determined by engineers, not wayward RV'er's!
Ok...so it is this one or the 2500 (which I assume gets worse gas mileage):
Trailering & Payload 5.3L EcoTec3 V8 engine 2WD
Curb Weight 5042 lbs
Max Payload 2007 lbs
Max GVWR 7200 lbs
Max Conventional Trailering, 3.73 Rear Axle 11400 lbs
GCWR, 3.73 Rear Axle 16700 lbs
Spring Axle Capacity 5.3L EcoTec3 V8 engine 2WD
Front Gross Axle Weight Rating 3650 lbs
Rear Gross Axle Weight Rating with 3.73 Rear Axle 4100 lbs
Mar-30-2014 09:02 PM
Mar-30-2014 08:54 PM
uintafly wrote:awoodwaring wrote:
This is actually my favorite trailer (but may go a little shorter due to liking state parks):
http://www.cruiserrv.com/products/shadow-cruiser/floorplans/item/s-314tsb
Hitch Weight (lbs) 725
Dry Weight (lbs) 6,290
Cargo Capacity (lbs) 3235
However, I am reluctant to go to the 2500 due to gas costs (it would be a day to day commuter...45 miles/185 days per year)
Unless you literally pack your entire house I can't see how you could pack 3,200 lbs of gear. (assuming you are not a full-timer). With my wife and 4 kids age 15 to 2 we load about 1,200 lbs, which includes 36 gallons of water (about 300 lbs.). I would say you would be fine with that trailer and probably would by > 8,000 lbs. loaded. With 2,000 lbs payload I personally wouldn't worry.
Mar-30-2014 08:53 PM
Mar-30-2014 08:51 PM
ib516 wrote:
I will disagree with the majority and say "it depends".
That truck will be what I would call 'marginal' for that load, but it will be doable if you plan short local trips. However, if you plan cross country trips or those that involve mountain grades, it'll be under powered IMO.
Mar-30-2014 07:51 PM
Mar-30-2014 07:48 PM
Mar-30-2014 07:20 PM
