2014 Cummins - 1/2 tank of unleaded drive 120 miles
ib516
What happened?
Not much.
Drain and flushed fuel system, $700 repair. No damage so says the owner. Go CP3! ๐Ÿ™‚
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
13 REPLIES 13
JamesBr
Gasoline in diesel is not good as the pumps, injectors and other components are not built for it. But unlike DEF in the fuel tank I would expect nothing more then having to drain and flush and some premature wear on the parts. Unlike DEF that crystalizes in the fuel system and causes major problems no matter what brand of truck you own.
2006 Ford F350 6.0
2014 Primetime Sanibel 3600
Enough other vehicles to not bother listing.
Previous RV: 2001 Monaco Knight
ScottG
Just because it didn't die right away doesn't mean he wont have a latent failure.
DirtyOil
Ya got me... guess you have a lot more courage then me
2013 RAM 3500 CTD Crew 4x4 Laramie
2014 Sprinter Copper Canyon 269FWRLS
GUTS GLORY RAM
patperry2766
DEF in fuel tank
I bet this guy would disagree with it causing no problems
"Would have no effect on the engine/fuel system, as DEF is injected downstream of the "vital" engine/fuel system, (injected into the exhaust stream).
Had to laugh at some of the "doom and gloom" or the "end of the world" posts. Almost as bad as another forum... which will remain nameless. Had a paramedic do that to one of our MTC units poor ole 6.0, F450 ambulance... dropped the tank flushed, changed the fuel filters a couple of times and think we put another 80k on it before selling it."
Courage is the feeling you have right before you fully understand the situation
patperry2766
Lowsuv
A long time camping buddy had the reverse problem .
His wife and her two sisters left PDX for SLC in his ford 460 motorhome .
They were going to a wedding in SLC of another long time GF .
They refueled on interstate 84 and the attendant put diesel in the tank .
The gals made it a few miles before it stopped running altogether .
It's been 15+ years but I think they flushed the tank and lines and got her going within a day or two .
DirtyOil
I think he meant if he had put in DEF instead of gasoline.
Yup, re-read about 3 more times... my bad!
GUTS GLORY RAM
fj12ryder
Howard and Peggy
"Don't Panic"
DirtyOil
Bet he wouldn't have fared as well if it had been DEF
GUTS GLORY RAM
Ram4Sam
This ought to make the blue oval fans Green with envy......he is a lucky man!
Sam
2016 Dodge cummins 3500 SRW LB CC 4X4 Aisin, Nav, white w/brown
No keys, B&W TOB & Companion
Gone....served me well...1991 Dodge Cummins...2001.5 Dodge Cummins
2008 Thor Jazz 2870UK 5er
Driving a Dodge Cummins since 1991...
stuckinthesand
That's good info to know.
Old-Biscuit
larry_barnhart
better to be lucky than good. Hope the engine is ok from the
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
