Apr-18-2016 06:08 PM
Apr-20-2016 08:22 AM
JIMNLIN wrote:op wrote:
I just want to be safe as the first priority.
Howdy neighbor.
I'm just up the road aways from Tulsa.
Just to let folks know in Oklahoma we have no weights to register our private use trucks at nor do we have to buy any weights for our tags. That for our commercial side.
As long as you stay within the trucks axle/tire load rating (FAWR/RAWR) you and everyone on the road will be safe. A GVWR or GCWR or tire placard number on newer trucks or a tow rating aren't used for any legal purposes. Your payload number your looking at just became mandatory in '06 so trucks before that year don't have a tire placard payload number although some truck makers started before '06.
As with any truck the owner/operator needs to know the trucks front and rear axle weight numbers .
Your 3500 SRW Mega's rear axle may weigh in the 3000 lb range which leaves the truck with a 3500 lb payload. Payload means the hitch/occupants/junk we carry plus the pin weight.
Load the truck road ready and get some separate axle weights. Then you know what your working with. The 3500 SRW diesel powered truck will pull anything the DRW will but its way short on wheel/tire and rear springs
Oh yeah when you get a scale ticket keep it in the trucks glove box for future reference.
Apr-20-2016 07:30 AM
Apr-19-2016 08:03 PM
dicksenn wrote:
The amount of information back and forth of whether the number listed on the door is just for registration, etc, and then use axle ratings, etc. is just overwhelming. Even Ram says my payload when I do a Vin lookup is 1890, then the door says 1503..
I realize the 2800lb hitch weights are out of the question but when it gets to closer numbers like the Sandpiper I'm really wondering if it's actually safe/feasible with air bags or if I'm just trying to convince myself it is.
Apr-19-2016 07:17 PM
dicksenn wrote:45Ricochet wrote:dicksenn wrote:
If I was comfortable with axle ratings and I went with the mfg rear weight listing of 3120 and the axles are rated at 6500 I would essentially have 3380 lbs to spare with cargo and all? Correct? I'd prefer to find some Cat Scales to verify.
So the Sandpiper I listed has a hitch weight of 1865, assuming another 800 for the family, hitch, and some gear I'd be at 2665 and have 715lbs to spare.
Still to much?
That is really common on this site with a 25 series truck. Fudging the numbers if needed :W Now a 35 series group will mention they are within GVWR and the duallies will still pull and hold ANY weight :B
Apr-19-2016 06:46 PM
Still to much?
Apr-19-2016 06:09 PM
Still to much?
Apr-19-2016 02:21 PM
Apr-19-2016 10:45 AM
Apr-19-2016 09:39 AM
Apr-19-2016 09:12 AM
Apr-19-2016 07:15 AM
dicksenn wrote:
As far as using the axle weights would I just get an actual truck weight from a scale divide by two considering the number of axles and then use the difference between that number and the GAWR of the rear axle?
Apr-19-2016 06:32 AM
IDoMyOwnStunts wrote:
I guess it all depends upon whether you want to stay within the official ratings. If not, then the only difference is 500 lbs between the rear axle on the 3500 mega cab and the rear axle on the 2500 mega cab (6500 vs 7000). Same front axle. Tires are more than capable. You can weigh your truck in camping configuration and then decide if you want to use the axle weights or the GVW as your limiting factor. If you want to use axle weights, then you've got a lot more options. But you really need to weigh your truck. Then you'll know.
You'll probably find that you would still need a dually for the fiver in the original post which can have a pin weight exceeding 4000 lbs if loaded up fully, but there are fivers that weigh much less than that one. If you use axle ratings, you aren't limited to travel trailers and you don't need to trade in your truck for a dually.
Apr-19-2016 05:42 AM
Apr-19-2016 04:28 AM
