Apr-29-2014 05:49 PM
May-03-2014 11:23 AM
May-03-2014 10:37 AM
travelnutz wrote:
ib516,
Obviously YOU have never been to the Big 3 engineering, testing, and certification centers or you'd actually know something about how they are done! So apparant that you DON'T or even have a clue. Keep reading your Mopar fiction and your mind kept closed!
travelnutz wrote:
ib516,
May-03-2014 09:03 AM
May-03-2014 08:46 AM
1wayhighway wrote:
Hey IB,
Looking at your signature and see you went back to gas. Looks like you have had a lot of experience with the diesel's and was just curious why you went back to gas? I think I see a diesel in my future so just trying to educate myself.
Thanks,
Dan R
May-03-2014 08:44 AM
travelnutz wrote:
Quote:
"When manufacturers certify HP ratings, there typically is an SAE representative to overlook the rating process."
Not true!
Cummins makes the diesel and sells it to Fiat/Chrysler/Dodge/Ram and Cummins gives their engines the HP and TQ values, NOT SAE. Not SAE certified and never was!
Ford uses 3-5 engines they'd test in the EEE building and they take the single highest values of the 3-5 (mix or match) with the standalone bare engines on the test stand not as in ready to install configuration. Not SAE certified!
GM Duramax tests and certifies with all SAE standards met completely and being present with ready to install configuration engines as on the assembly line. It IS SAE certified HP & TQ and GM displays the "SAE Certification Documents"!
YES, "There is a strict SAE standard for engine hp rating."
A little news for some of you posters: If the engine doesn't have the actual certified TQ & HP of another engine, it will NOT pull the same load equal or perform the same as the gear ratios of independent test venues are always matched as close as possible or it would be a tainted critera test and results. Some of you need to do some reading and research before you write your foolish posts.
Why do you think the lowly TQ & HP rated Duramax in production built trucks smokes both Ford and Cummins with much higher to much claimed TQ & HP and has for so many years now? Doesn't take half a brain to figure out why! NAA, no one would fudge any numbers or circumvent the established written rules of SAE to sound better in their favor, would they???
May-03-2014 08:31 AM
May-03-2014 06:36 AM
ib516 wrote:texasclarks wrote:
A pretty fair test (video 2). I hope they do the SuperDuty and RamHd soon.
x2.
I checked the engine temp gauge near the end of the video. Flat to the floor up that 7 mile long grade (trip said 7.4 miles or something) and no overheating (at least not on the digital imitation gauge). Pretty impressive.
May-02-2014 07:37 PM
jus2shy wrote:catfishmontana wrote:hoopers wrote:ksss wrote:
When GM made the updates in 2011, they were still below Ford in advertised power, but the GM twins swept nearly every pull off. I am not sure that will happen again with the revised 6.7 and Dodge now at 850. I am trying to decide if I care or not.
I met with the my Chevy commercial sales guy a couple days ago on a 2015 3500 SRW CC, LTZ. The numbers make sense. The value of my low mile LBZ is outstanding, makes stepping up to 2015 much easier.
I hate to say it, but I wonder how accurate all these advertised HP numbers are from the mfgr's? Is there a standard? Who checks the numbers to make sure they are accurate?
Yes, there is a standard.
When manufacturers certify HP ratings, there typically is an SAE representative to overlook the rating process. There is a strict SAE standard for engine hp rating. When engines are dyno'd, they typically have the full dress on them as well (PS pump, alternator, waterpump, ac compressor, etc). SAE link. So really look for that SAE certification when staring at power levels. However, what isn't rated so much is the HP curve and Torque curve. Remember that the ratings are merely peak numbers. So if 2 engines are within spitting distance of each other for HP (maybe within 10% of peak power), I'd pick the engine with the fatter torque curve. This would mean more available horsepower in more areas of the curve. I've done a comparison of the 390HP rated Ford 6.7L (initial power figure release) versus the F-150 tuned 6.2L gas motor. You can see how the horsepower is more readily available at just about any speed on the 6.7 versus the 6.2. I can only imagine the disparity growing with the 400/800 rating and the newest 440/860 rating. LINK
May-02-2014 01:45 PM
May-02-2014 10:04 AM
May-02-2014 09:30 AM
May-02-2014 09:11 AM
shelbyj wrote:
One thing that I don't like about their test runs is how they just "let" the tranny do the work. If I'm towing up a long grade like that I almost always put it in the gear it needs and go. Sometimes the tranny doesn't know best and with that last dodge video it was hunting quit a bit. No bueno.
May-02-2014 08:30 AM
