โAug-29-2015 08:47 AM
โNov-10-2015 11:31 AM
RinconVTR wrote:otrfun wrote:
The Cummins 5.0 V8 diesel "numbers" speak for themselves. In terms of raw torque (vs. 1/2 ton gas engines), I agree it's not a fair comparison--the Cummins 5.0 V8 comes out on top. You can play the HP card all day long, but big torque numbers at low RPM's is what makes for effortless towing in the realworld. Big HP numbers (relative to torque) require a lot of RPM's and constant transmission activity to maximize output---both distract from the ideal tow experience.
In the pickup market, yes only the EcoD. In the SUV market, there are many more to compare side by side with their gas engine options.
The Cummins 5.0 numbers do speak for themselves. They are low on HP compared to their competitive gas engine options. We can play the torque vs HP game all day, but the fact remains when you are full throttle under high load...just cause its a diesel doesn't mean its will hold under 2,000rpm where peak torque shows up.
You will be surprised to learn how high these diesels actually run when towing under stress. I suggest you pay closer attention...cause you are clearly missing this point.
โNov-10-2015 10:44 AM
RinconVTR wrote:ANY engine under "stress" or full throttle will be performing at the edge of its reliability/torque curve. What's your point?otrfun wrote:In the pickup market, yes only the EcoD. In the SUV market, there are many more to compare side by side with their gas engine options.
โNov-10-2015 10:05 AM
โNov-09-2015 07:43 PM
otrfun wrote:
IMO, the "no-man's land" (or "gap" as dshelly called it) is what fuels a lot of gas vs. big-bore diesel threads.
I think many will disagree with your assessment of the Cummins V8 5.0 diesel/torque/MPG experience. Rather doubt the 3.5EB, Hemi/Tundra 5.7, 6.2, 6.4, etc. are going to even come close in a realworld 10,000 lb. tow battle.
Although it may not be appealing to your needs, IMO Nissan has found a market path of least resistance . This path leads directly to a number of prospective and current 1/2 ton owners who want the diesel experience, but don't want to make the jump to a big-bore diesel.
RinconVTR wrote:Not sure what you're basing all your "night and day" towing test results on. Outside of the Ecodiesel is there any other small/medium diesel? Big HP/torque difference between the Ecodiesel and the Cummins 5.0 V8. Little ridiculous to lump them together from a performance perspective.
Are you thinking these smaller diesels will out perform their gas counter parts in the 1/2 ton truck market when it comes to towing? Think again. Its hardly a fair comparison.
Search for actual towing tests of ANY small/medium size diesel on the market right now. Regarding towing performance only...the difference is night and day. Gas engines, with their higher HP, make these smaller diesels painful to drive under strenuous towing conditions.
But hey...you might get 1 or even 3 better MPG....for drastically higher up front cost.
So you decide what the priority is. You'll get to your destination regardless.
โNov-09-2015 06:25 PM
8.1 Van wrote:
The Nissan Cummins Titan at the SEMA show in Las Vegas the past week:
Can this 2016 Nissan Titan XD capture the diesel land speed record?
Read more: http://autoweek.com/article/sema-show/2016-nissan-titan-xd-chases-diesel-land-speed-record#ixzz3r0L2roFJ
http://www.trucktrend.com/news/1511-2016-nissan-titan-xd-gets-measured-for-sema/
โNov-09-2015 06:10 PM
โNov-09-2015 05:49 PM
Bionic Man wrote:IMO, the "no-man's land" (or "gap" as dshelly called it) is what fuels a lot of gas vs. big-bore diesel threads.dshelley wrote:I would say that it is falling into no-man's land.
Looks like it will do what it was designed for. To fill a gap between the light duty half tons and the heavy duty 2500/3500's I like it. I like it a lot.
Engine is not powerful enough to offer a substantial power advantage over the 3.5 EB or Hemi (or the Chevy equivalent).
And it is not significantly more efficient than those above mentioned options either, so no big advantage in MPG.
I hope it is a winner for them. But I think they have a tough row to hoe.
โNov-09-2015 03:38 PM
โNov-09-2015 02:44 PM
โNov-09-2015 02:27 PM
IdaD wrote:Me Again wrote:
The very complex diesel would be a show stopped for me along with the CP4.2 injection pump. Chris
The chains and the injection pump would give me pause too. Plus I'm having a hard time coming up with an advantage with this truck compared to a regular heavy duty model. It isn't any cheaper and barely gets better mileage.
โNov-09-2015 02:11 PM
โNov-09-2015 02:10 PM
โNov-09-2015 01:23 PM
โNov-09-2015 01:03 PM
โNov-09-2015 12:53 PM
